I’m having a heck of a time getting an MC7455 working via USB to my GL-AR750S to connect to T-Mobile LTE (USA). I’ve been playing with the card configuration in Ubuntu but once I connect it to my GL-AR750S (Slate), it’s not detected by the GUI.
Here is the configuration of the MC7455 so far. It’s loaded with the last GENERIC firmware from Sierra Wireless:
It’s running the latest version of the GENERIC firmware. I’ve tried USBCOMP=8 and USBCOMP=9 and verified the changes via AT!USBCOMP? then saving it via AT!RESET but neither seem to work. If I run lsusb in shell on the Slate, it’s seen by the system:
Bus 001 Device 002: ID 1199:9071 Sierra Wireless, Inc.
If I unplug and plug it back in, this is what dmesg shows:
[ 701.517250] usb 1-1: new high-speed USB device number 3 using ehci-platform
[ 701.730338] usb 1-1: config 1 has an invalid interface number: 12 but max is 3
[ 701.738144] usb 1-1: config 1 has an invalid interface number: 13 but max is 3
[ 701.745833] usb 1-1: config 1 has an invalid interface number: 13 but max is 3
[ 701.753471] usb 1-1: config 1 has no interface number 1
[ 701.759093] usb 1-1: config 1 has no interface number 2
I know the USB sled I’m using works fine because I have used Quectel EC25-AF’s and EP06-A’s without issue in the same USB sled connected to the Slate.
Any help would be greatly appreciated. I’m sure it’s some configuration I need to do to the MC7455.
None. Although I remember seeing a post that I needed to add the ‘qcserial’ package which makes sense because when I use the MC7455 in the USB sled under Ubuntu 20.04, it’s ‘qcserial’ which creates ttyUSB0 through USB2 interfaces. I searched for it in LuCI but couldn’t find which package to add for ‘qcserial’. Granted, I didn’t look very hard.
None are created when plugged into the USB port of the Slate.
Also, quick update. The MC7455 works both under Windows 10 Pro (64-bit) and Ubuntu 20.04 without fuss connecting to T-Mobile (US) LTE. Even Carrier Aggregation works (B4+B12) so not sure why my Slate is having such a tough time with it.
Are there any other related packages for the MC7455 other than ‘qcserial’?
I got fed up and put the Quectel EC25-AF back into the USB sled and connected it back to the Slate. I’ll order another USB sled for the MC7455 and try testing again once the new USB sled arrives. Thanks for the help!
These are the only other two Qualcomm related packages I see that I don’t have installed on the Slate which might apply to the MC7455. The open-plc-utils doesn’t apply to WWAN cards I believe.
