GL-AR750S: tried > 128GB SD card?
I just wanted to see if anyone had tried larger than a 128GB SD card with the Slate and what the results were. The docs say only up to 128GB is supported, but you never know.
Thanks.
I tried a Samsung Evo 256Gb and yes it worked.
I have used my 1 TB micro SD card works perfectly good luck.
Anybody from GL-iNet has tested 1Tb SD card on AR750S and AR750 routers succesfully?
512Gb?
256Gb?
Thanks!
Yes I use my 1tb SanDisk SD card with my ar750s works great
Thanks ! It’s a good thing to know !
I noticed you stated SanDisk SD card.
does that mean an SD card in an SD cardreader in the usb port or a 1terabyte micro sd card in mmc/sdcard slot of the router.
Question to gli-techs. if you only state the mmc slot is only compatible up to 128gb, is this a physical limitation of the software and/or hardware, or just never been tested. thanks.
Yes it works n both an ad card reader and inside of the routers sd card slot
