Just updated my router to 3.003 testing version by selecting Upgrade / Local Upgrade in the interface. At first I got error message but once I disconnected wireguard and rebooted it installed.
However, all my installed plugins are wiped and also some script I had in root home directory.
@alzhao In the page you linked lower down is the procedure how to do it in Luci, so no need for the user to touch any files in SSH, just add the files to the keep list in Luci
If you build your own firmware image using the imagebuilder, you can add any packages you want to your custom firmware image, and they will already be installed when you flash the firmware.
That combined with saving the config files in Luci will do all you want
ok, but from below comments I would have expected directory contents to be preserved as well … does it make any difference if I upgrade from GL local update or the update function in Luci or does it do the same thing?
root@GL-AR750S:~/.ssh# cat /etc/sysupgrade.conf
This file contains files and directories that should
