Hello Everyone.
First post here. Not sure if this is the best place to share my thought, so please let me know if there is a better place/way to do it. After reading some reviews I purchased one unit to give it a test and see how it works before I get more. Here are my observations.
- First thing after looking at my unit I noticed that BETA label in the top/left corner. How far are we from actual release?
- Next, I noticed that you can go to the Advanced section which is for advanced users. Great. Since current default UI is missing some features (which I will get to in a second), is there a way to set up permanent Default vs Advanced UI? So on next login, I go directly to Default vs Advanced. Don’t get me wrong I think default UI is great default work.
- If I decide to stick with Advanced, is there a way to remove Default UI permanently? What is the plan in the long term? Keep both or one will replace the other? How much storage and RAM could be saved?
- In default UI I see an option to clone LAN MAC. Would it be possible to add WLAN cloning there as well?
- What does the Update button actually do in plugins section? Does it automatically update what is available? or it does check what is available for update?
- Plugin section is a little confusing to me. The filter only has ‘All’ or ‘Installed’. Would be great to expand and add Uninstalled as well Update. The first is self-explanatory but the other would show all packages which are available to updates. My first reaction after pressing the Update button was, the filter automatically jumped to “installed” and all packages had a button “Install” next to them. My first reaction was that this means “install” update. But actually, it is installed package which was not installed yet.
- It would be great to see the package size when clicking on the package name (description). Maybe add link to openwrt package info like [OpenWrt Wiki] package: tcpdump
- Before powering up my unit I inserting 128 SD Card, I wanted to format it as ext4. There is nothing in UI to allow formatting. Think this would be a great addition for some users. Id did see some other posts where people are confused about this as well.
- After ssh to my unit, I did not see mkfs / mkfs.ex4 utility so I could format it manually. I did search in packages section and did only find mkf2fs package. How do you format SD for supported file formats? I decided to remove SD card and format it on my Linux workstation and reinsert it for next boot.
- After booting up with newly formatted SD card and connected ethernet port 1 (wired) I do not see any shared volume in my Mac OS X Finder. I see that smbd is running.
- Also, File Sharing section I have ‘Share via LAN’ option that it is always on. I can not toggle this on/off. Is that an indication of some problem? For above point #10, Wifi Sharing and Writable are off on my system.
- Would it be possible to add SD Card space used on Default UI? Maybe add Status page above Internet, Wireless, etc where you could see all information like connection status, SD Bard Used, Internal Storage used for packages, etc. The Advanced move has memory used but I dod not see internal or external storage. Right now you have to ssh to the unit.
Perhaps there are some packages to address some of my suggestions? - Will this unit function with lighthttpd uninstalled? Does anyone know of good CLI FAQ/list to do everything from SSH is lighthttpd can be removed?
If not do you what section would be best to create such FAQ? - Is there was to modify default action when toiling physical switch on the side of unit. Script of some kind?
If I would like to help with adding some options to Default UI which project on github is for default UI?
Perhaps others have some other ideas to add?
