My GL AR750S works fine connecting to Wireguard VPN for few days at a time, then stops working for few days and so on. I can’t get what the issue is. System log gives the below problem. I removed the DNS from the Wireguard client. What’s strange is it works on some days and then stops working! Any ideas how to resolve?
Thanks!
Mon Nov 27 10:32:00 2023 daemon.info dnsmasq[22334]: exiting on receipt of SIGTERM
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: started, version 2.80 cachesize 150
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: DNS service limited to local subnets
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq-dhcp[24378]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: using local addresses only for domain test
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: using local addresses only for domain onion
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: using local addresses only for domain localhost
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: using local addresses only for domain invalid
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: using local addresses only for domain bind
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: using local addresses only for domain lan
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: reading /tmp/resolv.conf.auto
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: using nameserver 192.168.0.1#53
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: read /etc/hosts - 4 addresses
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq[24378]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Nov 27 10:32:01 2023 daemon.info dnsmasq-dhcp[24378]: read /etc/ethers - 0 addresses
Mon Nov 27 10:32:05 2023 kern.alert kernel: [ 2015.812609] fast-classifier: starting up
Mon Nov 27 10:32:05 2023 kern.alert kernel: [ 2015.816918] fast-classifier: registered
Mon Nov 27 10:32:05 2023 user.notice wiregaurd: client stop completed, del glwg.lock
