Package update fails either from WebUI or CLI. Reboot doesn’t not help.
error:
opkg_conf_load: Could not lock /var/lock/opkg.lock: Resource temporarily unavailable
unable to update / download packages.
I am on - OpenWrt Chaos Calmer 15.05 r47065 / LuCI for-15.05 branch (git-17.136.58961-13aa5ff)
I did the upgrade but it didnt go well. Unable to find packages ( minidlna) being used in the latest version so had to go back to earlier one working flawless since a year plus.
If there is no way to fix this issue, i will try upgrade again.
they have failed to install and transmission remote feature doesnt work - thank for your time and help, appreciate that.
I rolled back to my favorite 2.263 and everything working fine even opkg update issue has gone after flashing made router to default.
I request to keep / test the existing features of 2.263 in any new builds. I dont know any security related issues with that version but works like a charm.
The latest transmission packages support OpenSSL and mbedtls, which has improved security, why not use it? The transmission packages without encrypted have deprecated.
