I can not get a connection working with the LTE stick.
I plug the stick in and wait for it to show in the web ui.
I put it through the manual setup and then it just does not work. Sometimes I catch the “SIM card missing” error showing in the web ui.
At some point the stick does not show in the web ui any more and the log loops through the error all the time.
Please point me in the right direction to fix this.
Current Firmware Version 4.1.0
Firmware Type release7
Compile Time 2022-11-16 14:25:44(UTC+08:00)
cat /sys/kernel/debug/usb/devices
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev= 4.04
S: Manufacturer=Linux 4.4.60 xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=xhci-hcd.0.auto
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 4.04
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 26 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=12d1 ProdID=1506 Rev= 1.02
S: Manufacturer=HUAWEI Technology
S: Product=HUAWEI Mobile
C:* #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=10 Driver=option
E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=02 Prot=12 Driver=option
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I: If#= 2 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=02 Prot=16 Driver=huawei_cdc_ncm
E: Ad=84(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
I:* If#= 2 Alt= 1 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=16 Driver=huawei_cdc_ncm
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Output of logread.
Sun Mar 12 22:12:17 2023 kern.info kernel: [ 6074.247281] usb 1-1: new high-speed USB device number 7 using xhci-hcd
Sun Mar 12 22:12:17 2023 kern.info kernel: [ 6074.435825] usb-storage 1-1:1.0: USB Mass Storage device detected
Sun Mar 12 22:12:17 2023 kern.info kernel: [ 6074.436164] scsi host10: usb-storage 1-1:1.0
Sun Mar 12 22:12:17 2023 kern.info kernel: [ 6074.441864] usb-storage 1-1:1.1: USB Mass Storage device detected
Sun Mar 12 22:12:17 2023 kern.info kernel: [ 6074.445541] scsi host11: usb-storage 1-1:1.1
Sun Mar 12 22:12:17 2023 kern.info kernel: [ 6074.487387] usb 1-1: USB disconnect, device number 7
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6074.937293] usb 1-1: new high-speed USB device number 8 using xhci-hcd
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.082753] option 1-1:1.0: GSM modem (1-port) converter detected
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.082983] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.088809] option 1-1:1.1: GSM modem (1-port) converter detected
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.094978] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.120570] huawei_cdc_ncm 1-1:1.2: MAC-Address: 0c:5b:8f:27:9a:64
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.120623] huawei_cdc_ncm 1-1:1.2: setting rx_max = 16384
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.126096] huawei_cdc_ncm 1-1:1.2: setting tx_max = 16384
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.131730] huawei_cdc_ncm 1-1:1.2: NDP will be placed at end of frame for this device.
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.137119] huawei_cdc_ncm 1-1:1.2: cdc-wdm0: USB WDM device
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.146028] huawei_cdc_ncm 1-1:1.2 wwan0: register 'huawei_cdc_ncm' at usb-xhci-hcd.0.auto-1, Huawei CDC NCM device, 0c:5b:8f:27:9a:64
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.151010] usb-storage 1-1:1.3: USB Mass Storage device detected
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.164432] scsi host12: usb-storage 1-1:1.3
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.169531] usb-storage 1-1:1.4: USB Mass Storage device detected
Sun Mar 12 22:12:18 2023 kern.info kernel: [ 6075.173214] scsi host13: usb-storage 1-1:1.4
Sun Mar 12 22:12:19 2023 kern.notice kernel: [ 6076.167970] scsi 12:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Sun Mar 12 22:12:19 2023 kern.notice kernel: [ 6076.177870] scsi 13:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Sun Mar 12 22:12:19 2023 kern.notice kernel: [ 6076.180050] sd 13:0:0:0: [sda] Attached SCSI removable disk
Sun Mar 12 22:12:19 2023 kern.err kernel: [ 6076.397889] ubi0 error: ubi_open_volume: cannot open device 0, volume 2, error -16
Sun Mar 12 22:12:19 2023 kern.err kernel: [ 6076.397933] ubi0 error: ubi_open_volume: cannot open device 0, volume 2, error -16
Sun Mar 12 22:14:18 2023 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED e6:22:1b:bb:18:2e 0 0
Sun Mar 12 22:20:38 2023 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Sun Mar 12 22:20:40 2023 daemon.notice netifd: modem_1_1 (11734): Trying to set mode
Sun Mar 12 22:20:41 2023 daemon.notice netifd: modem_1_1 (11734): cat: can't open '/tmp/modem.xhci-hcd.0.auto/signal': No such file or directory
Sun Mar 12 22:20:41 2023 daemon.notice pppd[11960]: pppd 2.4.8 started by root, uid 0
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: abort on (BUSY)
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: abort on (NO CARRIER)
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: abort on (ERROR)
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: report (CONNECT)
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: timeout set to 10 seconds
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: send (AT&F^M)
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: expect (OK)
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: AT&F^M^M
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: OK
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: -- got it
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: send (ATE1^M)
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: ^M
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: ATE1^M^M
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: send (AT+CGDCONT=1,"IP","internet.telekom"^M)
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: timeout set to 30 seconds
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: AT+CGDCONT=1,"IP","internet.telekom"^M^M
Sun Mar 12 22:20:42 2023 local2.info chat[12003]: send (ATD*99***1#^M)
Sun Mar 12 22:20:43 2023 local2.info chat[12003]: expect (CONNECT)
Sun Mar 12 22:20:43 2023 local2.info chat[12003]: ^M
Sun Mar 12 22:20:43 2023 local2.info chat[12003]: ATD*99***1#^M^M
Sun Mar 12 22:20:43 2023 local2.info chat[12003]: CONNECT
Sun Mar 12 22:20:43 2023 local2.info chat[12003]: -- got it
Sun Mar 12 22:20:43 2023 local2.info chat[12003]: send ( ^M)
Sun Mar 12 22:20:43 2023 daemon.info pppd[11960]: Serial connection established.
Sun Mar 12 22:20:43 2023 kern.info kernel: [ 6579.833183] 3g-modem_1_1: renamed from ppp0
Sun Mar 12 22:20:43 2023 daemon.info pppd[11960]: Renamed interface ppp0 to 3g-modem_1_1
Sun Mar 12 22:20:43 2023 daemon.info pppd[11960]: Using interface 3g-modem_1_1
Sun Mar 12 22:20:43 2023 daemon.notice pppd[11960]: Connect: 3g-modem_1_1 <--> /dev/ttyUSB0
Sun Mar 12 22:20:44 2023 daemon.info pppd[11960]: CHAP authentication succeeded: Welcome!!
Sun Mar 12 22:20:44 2023 daemon.notice pppd[11960]: CHAP authentication succeeded
Sun Mar 12 22:21:16 2023 kern.err kernel: [ 6612.924739] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-2)
Sun Mar 12 22:21:16 2023 kern.err kernel: [ 6612.924790] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-2)
Sun Mar 12 22:21:16 2023 kern.err kernel: [ 6612.931551] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-2)
Sun Mar 12 22:21:16 2023 kern.info kernel: [ 6612.939701] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Sun Mar 12 22:21:16 2023 daemon.notice pppd[11960]: Modem hangup
Sun Mar 12 22:21:16 2023 daemon.notice pppd[11960]: Connection terminated.
Sun Mar 12 22:21:16 2023 kern.info kernel: [ 6612.947216] option 1-1:1.0: device disconnected
Sun Mar 12 22:21:16 2023 kern.info kernel: [ 6612.955114] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Sun Mar 12 22:21:16 2023 kern.info kernel: [ 6612.959335] option 1-1:1.1: device disconnected
Sun Mar 12 22:21:16 2023 kern.info kernel: [ 6612.967367] huawei_cdc_ncm 1-1:1.2 wwan0: unregister 'huawei_cdc_ncm' usb-xhci-hcd.0.auto-1, Huawei CDC NCM device
Sun Mar 12 22:21:16 2023 daemon.info pppd[11960]: Exit.
Sun Mar 12 22:21:16 2023 daemon.notice netifd: Interface 'modem_1_1' is now down
Sun Mar 12 22:21:16 2023 kern.info kernel: [ 6613.205632] usb 1-1: reset high-speed USB device number 8 using xhci-hcd
Sun Mar 12 22:21:16 2023 user.notice mwan3[13661]: Execute ifdown event on interface modem_1_1 (unknown)
Sun Mar 12 22:21:17 2023 kern.err kernel: [ 6614.104630] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
Sun Mar 12 22:21:18 2023 kern.err kernel: [ 6615.004569] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
Sun Mar 12 22:21:18 2023 kern.info kernel: [ 6615.124610] usb 1-1: reset high-speed USB device number 8 using xhci-hcd
Sun Mar 12 22:21:18 2023 kern.err kernel: [ 6615.544540] usb 1-1: device not accepting address 8, error -22
Sun Mar 12 22:21:18 2023 kern.info kernel: [ 6615.664585] usb 1-1: reset high-speed USB device number 8 using xhci-hcd
Sun Mar 12 22:21:19 2023 kern.err kernel: [ 6616.084543] usb 1-1: device not accepting address 8, error -22
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.084674] usb 1-1: USB disconnect, device number 8
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.084752] option 1-1:1.0: GSM modem (1-port) converter detected
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.084968] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.085069] option 1-1:1.1: GSM modem (1-port) converter detected
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.085226] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Sun Mar 12 22:21:19 2023 kern.err kernel: [ 6616.086429] xhci-hcd xhci-hcd.0.auto: ERROR: unexpected command completion code 0x13.
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.086447] usb 1-1: Not enough bandwidth for altsetting 0
Sun Mar 12 22:21:19 2023 kern.warn kernel: [ 6616.086472] huawei_cdc_ncm: probe of 1-1:1.2 failed with error -22
Sun Mar 12 22:21:19 2023 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.133615] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.139475] option 1-1:1.0: device disconnected
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.147616] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.151842] option 1-1:1.1: device disconnected
Sun Mar 12 22:21:19 2023 daemon.notice netifd: Interface 'modem_1_1' is now down
Sun Mar 12 22:21:19 2023 user.notice mwan3[14187]: Execute ifdown event on interface modem_1_1 (unknown)
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.554576] usb 1-1: new high-speed USB device number 9 using xhci-hcd
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.699652] option 1-1:1.0: GSM modem (1-port) converter detected
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.699868] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.705761] option 1-1:1.1: GSM modem (1-port) converter detected
Sun Mar 12 22:21:19 2023 kern.info kernel: [ 6616.712116] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Sun Mar 12 22:21:20 2023 kern.info kernel: [ 6616.737082] huawei_cdc_ncm 1-1:1.2: MAC-Address: 0c:5b:8f:27:9a:64
Sun Mar 12 22:21:20 2023 kern.info kernel: [ 6616.737116] huawei_cdc_ncm 1-1:1.2: setting rx_max = 16384
Sun Mar 12 22:21:20 2023 kern.info kernel: [ 6616.743866] huawei_cdc_ncm 1-1:1.2: setting tx_max = 16384
Sun Mar 12 22:21:20 2023 kern.info kernel: [ 6616.747967] huawei_cdc_ncm 1-1:1.2: NDP will be placed at end of frame for this device.
Sun Mar 12 22:21:20 2023 kern.info kernel: [ 6616.753573] huawei_cdc_ncm 1-1:1.2: cdc-wdm0: USB WDM device
Sun Mar 12 22:21:20 2023 kern.info kernel: [ 6616.762032] huawei_cdc_ncm 1-1:1.2 wwan0: register 'huawei_cdc_ncm' at usb-xhci-hcd.0.auto-1, Huawei CDC NCM device, 0c:5b:8f:27:9a:64
Sun Mar 12 22:21:20 2023 kern.info kernel: [ 6616.767328] usb-storage 1-1:1.3: USB Mass Storage device detected
Sun Mar 12 22:21:20 2023 kern.info kernel: [ 6616.789357] scsi host14: usb-storage 1-1:1.3
Sun Mar 12 22:21:20 2023 kern.info kernel: [ 6616.789972] usb-storage 1-1:1.4: USB Mass Storage device detected
Sun Mar 12 22:21:20 2023 kern.info kernel: [ 6616.792861] scsi host15: usb-storage 1-1:1.4
Sun Mar 12 22:21:21 2023 kern.notice kernel: [ 6617.785873] scsi 14:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Sun Mar 12 22:21:21 2023 kern.notice kernel: [ 6617.796057] scsi 15:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Sun Mar 12 22:21:21 2023 kern.notice kernel: [ 6617.799275] sd 15:0:0:0: [sda] Attached SCSI removable disk
Sun Mar 12 22:21:24 2023 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Sun Mar 12 22:21:25 2023 kern.err kernel: [ 6622.015984] ubi0 error: ubi_open_volume: cannot open device 0, volume 2, error -16
Sun Mar 12 22:21:25 2023 kern.err kernel: [ 6622.016031] ubi0 error: ubi_open_volume: cannot open device 0, volume 2, error -16
Sun Mar 12 22:21:26 2023 daemon.notice netifd: modem_1_1 (15853): Trying to set mode
Sun Mar 12 22:21:27 2023 daemon.notice netifd: modem_1_1 (15853): cat: can't open '/tmp/modem.xhci-hcd.0.auto/signal': No such file or directory
Sun Mar 12 22:21:27 2023 daemon.notice pppd[16500]: pppd 2.4.8 started by root, uid 0
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: abort on (BUSY)
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: abort on (NO CARRIER)
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: abort on (ERROR)
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: report (CONNECT)
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: timeout set to 10 seconds
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: send (AT&F^M)
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: expect (OK)
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: AT&F^M^M
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: OK
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: -- got it
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: send (ATE1^M)
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: ^M
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: ATE1^M^M
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: send (AT+CGDCONT=1,"IP","internet.telekom"^M)
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: timeout set to 30 seconds
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: AT+CGDCONT=1,"IP","internet.telekom"^M^M
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: send (ATD*99***1#^M)
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: expect (CONNECT)
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: ATD*99***1#^M^M
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: CONNECT
Sun Mar 12 22:21:28 2023 local2.info chat[16508]: send ( ^M)
Sun Mar 12 22:21:28 2023 daemon.info pppd[16500]: Serial connection established.
Sun Mar 12 22:21:28 2023 kern.info kernel: [ 6625.683216] 3g-modem_1_1: renamed from ppp0
Sun Mar 12 22:21:28 2023 daemon.info pppd[16500]: Renamed interface ppp0 to 3g-modem_1_1
Sun Mar 12 22:21:28 2023 daemon.info pppd[16500]: Using interface 3g-modem_1_1
Sun Mar 12 22:21:28 2023 daemon.notice pppd[16500]: Connect: 3g-modem_1_1 <--> /dev/ttyUSB0
Sun Mar 12 22:21:30 2023 daemon.info pppd[16500]: CHAP authentication succeeded: Welcome!!
Sun Mar 12 22:21:30 2023 daemon.notice pppd[16500]: CHAP authentication succeeded
Sun Mar 12 22:21:30 2023 kern.err kernel: [ 6627.324764] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-2)
Sun Mar 12 22:21:30 2023 kern.err kernel: [ 6627.324803] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-2)
Sun Mar 12 22:21:30 2023 kern.err kernel: [ 6627.331577] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-2)
Sun Mar 12 22:21:30 2023 kern.err kernel: [ 6627.339305] option1 ttyUSB0: usb_wwan_indat_callback: resubmit read urb failed. (-2)
Sun Mar 12 22:21:30 2023 daemon.notice pppd[16500]: Modem hangup
Sun Mar 12 22:21:30 2023 daemon.notice pppd[16500]: Connection terminated.
Sun Mar 12 22:21:30 2023 kern.info kernel: [ 6627.347791] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Sun Mar 12 22:21:30 2023 kern.info kernel: [ 6627.355348] option 1-1:1.0: device disconnected
Sun Mar 12 22:21:30 2023 kern.info kernel: [ 6627.362895] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Sun Mar 12 22:21:30 2023 kern.info kernel: [ 6627.367244] option 1-1:1.1: device disconnected
Sun Mar 12 22:21:30 2023 kern.info kernel: [ 6627.375566] huawei_cdc_ncm 1-1:1.2 wwan0: unregister 'huawei_cdc_ncm' usb-xhci-hcd.0.auto-1, Huawei CDC NCM device
Sun Mar 12 22:21:30 2023 daemon.info pppd[16500]: Exit.
Sun Mar 12 22:21:30 2023 daemon.notice netifd: Interface 'modem_1_1' is now down
Sun Mar 12 22:21:30 2023 kern.info kernel: [ 6627.595653] usb 1-1: reset high-speed USB device number 9 using xhci-hcd
Sun Mar 12 22:21:30 2023 user.notice mwan3[16692]: Execute ifdown event on interface modem_1_1 (unknown)
Sun Mar 12 22:21:31 2023 kern.err kernel: [ 6627.714580] usb 1-1: device descriptor read/64, error -71
Sun Mar 12 22:21:31 2023 kern.err kernel: [ 6627.944562] usb 1-1: device descriptor read/64, error -71
Sun Mar 12 22:21:31 2023 kern.info kernel: [ 6628.184519] usb 1-1: reset high-speed USB device number 9 using xhci-hcd
Sun Mar 12 22:21:31 2023 kern.warn kernel: [ 6628.304569] usb 1-1: Device not responding to setup address.
Sun Mar 12 22:21:31 2023 kern.warn kernel: [ 6628.514556] usb 1-1: Device not responding to setup address.
Sun Mar 12 22:21:32 2023 kern.err kernel: [ 6628.724482] usb 1-1: device not accepting address 9, error -71
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6628.844610] usb 1-1: reset high-speed USB device number 9 using xhci-hcd
Sun Mar 12 22:21:32 2023 kern.warn kernel: [ 6628.844690] usb 1-1: Device not responding to setup address.
Sun Mar 12 22:21:32 2023 kern.warn kernel: [ 6629.054527] usb 1-1: Device not responding to setup address.
Sun Mar 12 22:21:32 2023 kern.err kernel: [ 6629.264478] usb 1-1: device not accepting address 9, error -71
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6629.384507] usb 1-1: reset high-speed USB device number 9 using xhci-hcd
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6629.410587] option 1-1:1.0: GSM modem (1-port) converter detected
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6629.410845] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6629.415947] option 1-1:1.1: GSM modem (1-port) converter detected
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6629.423017] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Sun Mar 12 22:21:32 2023 kern.warn kernel: [ 6629.431621] huawei_cdc_ncm: probe of 1-1:1.2 failed with error -71
Sun Mar 12 22:21:32 2023 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6629.455225] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6629.455298] option 1-1:1.0: device disconnected
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6629.462717] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6629.467440] option 1-1:1.1: device disconnected
Sun Mar 12 22:21:32 2023 daemon.notice netifd: Interface 'modem_1_1' is now down
Sun Mar 12 22:21:32 2023 kern.info kernel: [ 6629.595955] usb 1-1: reset high-speed USB device number 9 using xhci-hcd
Sun Mar 12 22:21:33 2023 kern.warn kernel: [ 6629.714860] usb 1-1: Device not responding to setup address.
Sun Mar 12 22:21:33 2023 user.notice mwan3[17209]: Execute ifdown event on interface modem_1_1 (unknown)
Sun Mar 12 22:21:33 2023 kern.warn kernel: [ 6629.924515] usb 1-1: Device not responding to setup address.
Sun Mar 12 22:21:33 2023 kern.err kernel: [ 6630.134482] usb 1-1: device not accepting address 9, error -71
Sun Mar 12 22:21:33 2023 kern.info kernel: [ 6630.254523] usb 1-1: reset high-speed USB device number 9 using xhci-hcd
Sun Mar 12 22:21:33 2023 kern.err kernel: [ 6630.374533] usb 1-1: device descriptor read/64, error -71
Sun Mar 12 22:21:33 2023 kern.err kernel: [ 6630.604565] usb 1-1: device descriptor read/64, error -71
Sun Mar 12 22:21:34 2023 kern.info kernel: [ 6630.834535] usb 1-1: reset high-speed USB device number 9 using xhci-hcd
Sun Mar 12 22:21:34 2023 kern.err kernel: [ 6630.854699] usb 1-1: device descriptor read/8, error -71
Sun Mar 12 22:21:34 2023 kern.err kernel: [ 6630.984734] usb 1-1: device descriptor read/8, error -71
Sun Mar 12 22:21:35 2023 kern.info kernel: [ 6632.054521] usb 1-1: reset high-speed USB device number 9 using xhci-hcd
Sun Mar 12 22:21:35 2023 kern.warn kernel: [ 6632.054577] usb 1-1: Device not responding to setup address.
Sun Mar 12 22:21:35 2023 kern.warn kernel: [ 6632.264504] usb 1-1: Device not responding to setup address.
Sun Mar 12 22:21:35 2023 kern.err kernel: [ 6632.474462] usb 1-1: device not accepting address 9, error -71
Sun Mar 12 22:21:35 2023 kern.info kernel: [ 6632.474587] usb 1-1: USB disconnect, device number 9
Sun Mar 12 22:21:35 2023 kern.info kernel: [ 6632.474671] option 1-1:1.0: GSM modem (1-port) converter detected
Sun Mar 12 22:21:35 2023 kern.info kernel: [ 6632.475078] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Sun Mar 12 22:21:35 2023 kern.info kernel: [ 6632.475194] option 1-1:1.1: GSM modem (1-port) converter detected
Sun Mar 12 22:21:35 2023 kern.info kernel: [ 6632.475484] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Sun Mar 12 22:21:35 2023 kern.info kernel: [ 6632.503705] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Sun Mar 12 22:21:35 2023 kern.info kernel: [ 6632.510190] option 1-1:1.0: device disconnected
Sun Mar 12 22:21:35 2023 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Sun Mar 12 22:21:35 2023 kern.info kernel: [ 6632.518365] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Sun Mar 12 22:21:35 2023 kern.info kernel: [ 6632.522534] option 1-1:1.1: device disconnected
Sun Mar 12 22:21:35 2023 daemon.notice netifd: Interface 'modem_1_1' is now down
Sun Mar 12 22:21:36 2023 user.notice mwan3[17745]: Execute ifdown event on interface modem_1_1 (unknown)
Sun Mar 12 22:21:36 2023 kern.info kernel: [ 6632.934499] usb 1-1: new high-speed USB device number 10 using xhci-hcd
Sun Mar 12 22:21:36 2023 kern.warn kernel: [ 6633.054560] usb 1-1: Device not responding to setup address.
Sun Mar 12 22:21:36 2023 kern.warn kernel: [ 6633.264587] usb 1-1: Device not responding to setup address.
Sun Mar 12 22:21:36 2023 kern.err kernel: [ 6633.474504] usb 1-1: device not accepting address 10, error -71
Sun Mar 12 22:21:36 2023 kern.info kernel: [ 6633.594507] usb 1-1: new high-speed USB device number 11 using xhci-hcd
Sun Mar 12 22:21:37 2023 kern.err kernel: [ 6633.714633] usb 1-1: device descriptor read/64, error -71
Sun Mar 12 22:21:37 2023 kern.err kernel: [ 6633.944540] usb 1-1: device descriptor read/64, error -71
Sun Mar 12 22:21:38 2023 kern.err kernel: [ 6634.954485] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
Sun Mar 12 22:21:39 2023 kern.err kernel: [ 6635.854512] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
Sun Mar 12 22:21:39 2023 kern.err kernel: [ 6635.854638] usb usb1-port1: unable to enumerate USB device
