fmccann
November 29, 2022, 7:42pm
Running:
GL-AX1800 firmware: 3.214
AdGuard Home: v0.107.19
When AdGuard home is enabled, DNS resolution is dramatically slower and often fails. I’ve tried changing upstream DNS servers and disabling all filters but nothing seems to make a difference.
Any ideas for troubleshooting steps?
alzhao
November 30, 2022, 10:01am
2
Can you try 4.1.0 firmware?
fmccann
November 30, 2022, 1:51pm
3
I tried a local upgrade with the file:
openwrt-axt1800-4.1.0-1116-1668588068.tar
And I get this error:
failed! ERROR: Incorrect firmware format!
fmccann:
GL-AX1800
jdub
November 30, 2022, 1:56pm
4
The AXT1800 and AX1800 are different routers. Make sure you’ve got the correct firmware for the device you’re flashing (you don’t).
fmccann
November 30, 2022, 2:58pm
5
OK, I went to the product page:
And donwloaded:
openwrt-ax1800-4.1.0-1114-1668412657.tar
This also gives me the error:
jdub
November 30, 2022, 3:11pm
6
You might try the uboot version if you’re having problems:
https://dl.gl-inet.com/?model=ax1800
