Thanks @Exile1975 and @lizh I was able to upgrade AdGuardHome to 0.106.3 but I had to setup it again, my settings for 0.104.3 was cleared after the upgrade
After the update to 3.207, AdGuardHome did not work for me (version 0.106.3 was working before the update ). The Plugins page indicated the latest (0.106.3) was intalled and offered only the uninstall option.
However, in the ssh console, the system showed (opkg list-installed) version 0.104.3 was installed. Therefore, I ran opkg upgrade AdGuardHome, then /etc/init.d/AdGuardHome start and everything is working now.
Thank you I will try your fix and see how it goes. Appreciate the details very much.
Thanks.
Yes now with 4.2.1 works
