How can I change from Single WAN port to 2 WAN ports?
Possible?
Sure, 1 of these 2 ways you choose:
1.Config on the Luci:
a. Luci -> Network -> Interfaces -> Devices -> br-lan -> config... -> uncheck the LAN1 (eth1)
b. Luci -> Network -> Interfaces -> (slide to the bottom) Add -> Create the secondwan, select the LAN1 (eth1), DHCP or static, select the WAN group of the firewall.
c. Save and apply.
- Config on the SSH of router, execute these commands, and will create DHCP secondwan (LAN1):
# /etc/config/network
uci del network.cfg030f15.ports
uci add_list network.cfg030f15.ports='eth2'
uci add_list network.cfg030f15.ports='eth3'
uci add_list network.cfg030f15.ports='eth4'
uci set network.cfg030f15.bridge_empty='1'
uci set network.secondwan=interface
uci set network.secondwan.device='eth1'
uci set network.secondwan.proto='dhcp'
# /etc/config/firewall
uci del firewall.cfg03dc81.network
uci add_list firewall.cfg03dc81.network='wan'
uci add_list firewall.cfg03dc81.network='wan6'
uci add_list firewall.cfg03dc81.network='wwan'
uci add_list firewall.cfg03dc81.network='secondwan'
Note: the 'secondwan' will not display on the GL GUI.
Thanks for the reply and guide
Thank you.
I'm so new in a GLs specifics.
Ok, now I have two WAN ports
A few findings:
- Please be careful with marking on a box: eth1 = LAN2 & eth2 = LAN1
- To avoid client DHCP flipping from one src network to another - configure your own DHCP IP networks and range. This will keep it stable.
- In /etc/config/network I have enriched the WAN2 by the following:
config interface 'WAN2'
option device 'eth1'
option proto 'dhcp'
option force_link '0'
option ipv6 '0'
option classlessroute '0'
option metric '5'
option vlanid '0'
option peerdns '1'
and re-plug the cable to the correct port (see p.1)
FOr more details Dual wan - #6 by JimC and Dual ethernet wan for GL-AXT1800
Thank you in advance.
