I don’t what is blocking my communication on open ports
I’ve changed default router ip address and opened some ports on port forwarding page. Pinging my external SSL domain gets response from router ip but when i open home page of that device, nothing happens (ERR_CONNECTION_TIMED_OUT)
I found the problem
only 1 ip address can use 1 port number
2 different ip addresses CANNOT use same opened port
This is disgusting! I want one device to use port 443 and another device to also use port 443 but router won’t allow both
edit: My old router allowed me to set port forwarding for one device and for another device, i put it on DMZ list (which worked) but here, I can put either port forward rule for 1 device OR use DMZ (otherwise go to LuCi [aka hell])
It was dLink router and it allowed me to set port forwarding rules for my first device then,… for my NAS, there were issues so I put NAS IP address on DMZ list and from there both devices were working fine
Maybe DLINK guys allowed both DMZ and port forwarding
Edit: I’m point you to another brand’s forum where user had similar issue and he asked whether he can use DMZ and port forwarding together. In his response, he got a YES (but that’s not the case with gl-inet )
