GL-AX1800 Flint - 4.2 - Constantly crashing
I configured my GL-AX1800 Flint the same way as I did with version 3.2 but my device is randomly crashing.
With version 3.2 I could have an uptime of almost a month, but with version 4.2 I can be happy, if it reaches
a full day. This is extremely annoying. My bootloader is also up to date.
What could cause these crashes? How can I log them?
Is there any content in the Logs page?
Pls send details of your config and pls export and send the log.
I have a similar issue in another thread:
 thanks
regards
There is unfortunately no Crash log. At the moment I didn’t have any crashes for more than 8 days, which is a new record. I will monitor it further.
I’m still having reboot.
I had another reboot, and the system upload bearly arrived to 3 days.
I just run the reset of the firmware, and recover all the info with a backup (just specify, because I think that the backup only contain name and password, and not installed package for example).
I bought this router more than one month ago in amazon, but I’m thinking to ask for a replace.
if Someone from Gl.Inet can give me other info I will be happy.
Just to recap, I already:
  1. I moved the modem to a different energy socket;
  2. Just reset the firmware and I will keep an eye;
  3. no logs anywhere about this reboot;Thanks.
    regards
    Piero
UPDATE: after the refresh of the firmware I had the first unexpected reboot in less than 15 minutes…
If power and cooling is not the issue, you can ask customer service to get a replacement.
Hi Thanks, I asked for a replacement.
Thanks.
I have actually 2x the GL-AX1800. Both show the same crashing symptoms with Firmware 4.2.1.
My current configuration:
VPN connection to Mullvad
Public WiFi with static channels
Some firewall rules to prevent accessing the WebUI from the WiFi.
@alzhao Do you need the config file exported by OpenWRT?
Sorry for missing this. Still able to provide config?
Yes, I will send you a link by PM when I’m home. The config contains a wireguard VPN connection. Do you need a functional one?
@alzhao
