In iOS, the randomized MAC address feature assigns a unique MAC address to each Wi-Fi network and keeps the same address for subsequent connections to that network, instead of changing it on every reboot. Additionally, this feature can be disabled for specific networks, like your home Wi-Fi, allowing your device to use its real MAC address instead.
1.@admon Not using MAC based access list is not a solutions… I need this in order to filter devices and allow connection to use VPN
@slesar Don’t share password WiFi. I hope that;s an joke . is not a solutions (device need to use the connections)
@meo solutions to use real MAC address is good but outside of this wifi , users should use that privacy mac feature for tracking and security reasons
So If I understand it’s no way using GL-AX1800 Flint / v4.4.6 the to block some devices by MAC address to use the connections. or limit some day hours ! ()
Even Parental Control is not useful .
you said “… but when a APPLE device it’s rebooted it’s change the MAC address.”
This shouldn’t be the case, as long as the device connects to the same AP, the device will keep its randomised address and NOT generate a new one. Worth a recheck.
you said “solutions to use real MAC address is good but outside of this wifi , users should use that privacy mac feature for tracking and security reasons”
You can turn off apple’s devices MAC randomisation per AP, you can disable it only for your home AP and it will still be enabled for other APs.
Indeed. This is behind of scope for this device.
You need some captive portal. Might be possible with OpenWrt but tbh, just go for a professional firewall like Sophos then.
Each time these network interfaces are started, new random addresses are generated and a unique address is generated for each interface as required and independently of each other
From here:
Starting with iOS 15, iPadOS 15 and watchOS 8, if your device hasn’t joined the network in six weeks, it will use a different private address the next time it connects to that network. And if you make your device forget the network, it will also forget the private address it used with that network, unless it has been less than two weeks since the last time it was made to forget that network.
Alternatively, disable apple’s devices randomisation only for your own Access Point.
