I am running a simple 5 GHz wireless network (80MHz, channel 48) secured with WPA-PSK2. All of my computers and mobile devices experience frequent loss of wireless connectivity while still claiming to be connected to the network. This manifests with eg. inability to load a website, lack of response during SSH session or video buffering. The issue disappears for after a minute or two and the network keeps on working fine a few minutes until the problem appears again.
The problem is not reproducible on my old router (Netgear R6220 running OpenWRT 21.02) which I needed to replace due to its 2.4 GHz radio that recently died.
Do you have any ideas what I should look for?
What log files would you need to shine some light on the issue from your side?
I plan to run leave a ping command running on three devices - the router, computer connected to wireless network, and computer connected to Ethernet interface. I also play to run mtr program on the device connected to wireless network.
By the way, right now I am seriously considering returning the router as it is unusable for its purpose which is sad to experience.
Yeah, there was one Wifi network known by the repeater which I used for a few minutes just after unpacking the router. I have removed it and the issue is gone, router has been working perfectly for a few hours now. Great, thanks for your help!
Funny thing, when swapping the old and new router, I named the new network exactly the same so Flint remembered the network it broadcasted by himself (at least from user point of view, I don’t remember if the Wifi network have some random identifier part or it is completely derived from its name). Then I connected the to WAN with a cable without turning off the repeater in any way.
