Running 4.8.3 (latest release) on GL-AX1800, ipq6018, WiFi firmware WLAN.HK.2.7.0.1-02409 (build 2024-08-07), kernel 5.4.164.
Intermittently the WiFi firmware crashes, and instead of recovering the radio the ath11k SSR notifier panics, which takes the whole router down and forces a hard reboot. Reboot takes 60-90 seconds; all wired and wireless clients drop. It has happened repeatedly over several months, at random intervals - no scheduled reboot configured, no thermal or memory pressure (65-66 C, 414 MB RAM, load normal).
Full trace from pstore (console-ramoops-0):
CPU: 0 PID: 23913 Comm: kworker/0:1 Tainted: G C 5.4.164 #0
Hardware name: GL Technologies, Inc. AX1800 (DT)
Workqueue: rproc_wq rproc_crash_handler_work
pc : ath11k_core_ssr_notifier_cb+0xd8/0x120 [ath11k]
lr : ath11k_core_ssr_notifier_cb+0xc8/0x120 [ath11k]
Call trace:
blocking_notifier_call_chain+0x7c/0xb0
rproc_subsys_notify+0x7c/0x8c
rproc_trigger_recovery+0x74/0x284
rproc_crash_handler_work+0xcc/0xd0
process_one_work+0x1b4/0x320
worker_thread+0x6c/0x440
kthread+0x128/0x154
ret_from_fork+0x10/0x24
Code: f9400260 91404800 3945c000 35fffb20 (d4210000)
---[ end trace 808467fbe88a3610 ]---
Kernel panic - not syncing: Fatal exception
SMP: stopping secondary CPUs
Rebooting in 3 seconds..
The same trace has been reported here by another Flint owner on 4.5.16 (Oct 2024), so this looks long-standing rather than specific to 4.8.3.
Questions:
- Is this ath11k SSR path addressed in the 4.8.4 beta, or is a fix planned?
- Is there any recommended mitigation (channel width, 802.11ax / HE settings, WDS, MIMO/beamforming options) known to reduce how often the WiFi firmware crash that triggers this occurs?
- Anything specific you want captured from the device when it next happens? I can supply full pstore dumps and have remote syslog enabled now.
Thank you for the detailed report and crash trace.
Could you please send us the full pstore crash dump and the system logs leading up to the reboot via private message? We’ll forward them to our R&D team for review.
Following up — no reply since November 3, and the crashes have continued on 4.8.3 (GL-AX1800, ipq6018, WLAN.HK.2.7.0.1-02409, no scheduled reboot configured).
Nov 8: four crashes (02:07, 02:47, 03:05, 18:55). Nov 10: three so far — 08:10, 08:20 and 11:00 local time, each with a fresh ath11k_core_ssr_notifier_cb+0xd8/0x120 trace, Workqueue: rproc_wq rproc_crash_handler_work. The current boot started at 11:08, so at the time of writing the router had been up for about two minutes.
That is 13 confirmed panics now, with intervals ranging from ten minutes to over twenty hours. It does not correlate with load, temperature (65-66 C) or memory, and the sched 03:00 daily reboot is not involved in these.
I sent the full pstore dumps and pre-crash syslog to @will.qiu by private message on November 3, and I have newer dumps from Nov 6, 7, 8 and today ready to add to the same thread.
Could someone confirm:
- whether R&D has reviewed the submitted trace, and
- whether anything in the 4.8.4 beta touches the ath11k SSR / rproc recovery path, or whether a mitigation (channel width, 802.11ax/HE settings, WDS, beamforming) is recommended in the meantime.
Happy to supply the newer dumps immediately if they would help.
Sorry, forgot to follow up, and thank you for sending the logs.
Yes, the logs have been submitted to our R&D team for analysis. The investigation is taking longer because it involves the underlying Wi-Fi driver.
We don’t need any additional information at this stage. We’ll let you know when we have an update or need your help with further checks.
We're sharing a test firmware with you via private message. Could you please install it and check whether the crashes and unexpected reboots still occur?
If it happens again, please send us the new pstore crash dump and system logs via private message, along with the approximate time of the reboot, so we can investigate further. Thank you for your help with testing.
