GL-AX1800 / FW 4.7.0, cryptsetup/kmod-crypto-* related components are not working correctly
Since upgrading my GL-AX1800 / Flint to Firmware 4.7.0, several OpenWrt (opkg) packages were missing for a while. However, many of the packages I need are now returning (though not all of them yet).
Recently, cryptsetup and its related packages, which are necessary for dm-crypt (encrypted storage), were finally released. This package was highly anticipated as I share dm-crypt/LUKS encrypted storage via Samba on my LAN.
However, when I tried to use it, most of cryptsetup's functions do not work.
root@META-Flint:~# lsblk /dev/sdc -f
NAME   FSTYPE      FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sdc
└─sdc1 crypto_LUKS             a4d000c1-1b34-406d-a6e0-79695cdee6c2
root@META-Flint:~# cryptsetup luksOpen /dev/sdc1 luks-data
Cannot initialize crypto backend.
Device /dev/sdc1 is not a valid LUKS device.
root@META-Flint:~#
Even when running cryptsetup benchmark:
root@META-Flint:~# cryptsetup benchmark
# Tests are approximate using memory only (no storage IO).
PBKDF2-sha1          N/A
PBKDF2-sha256        N/A
PBKDF2-sha512        N/A
PBKDF2-ripemd160     N/A
PBKDF2-whirlpool     N/A
argon2i    N/A
argon2id   N/A
#     Algorithm |       Key |      Encryption |      Decryption
        aes-cbc        128b               N/A               N/A
    serpent-cbc        128b               N/A               N/A
    twofish-cbc        128b               N/A               N/A
        aes-cbc        256b               N/A               N/A
    serpent-cbc        256b               N/A               N/A
    twofish-cbc        256b               N/A               N/A
        aes-xts        256b               N/A               N/A
    serpent-xts        256b               N/A               N/A
    twofish-xts        256b               N/A               N/A
        aes-xts        512b               N/A               N/A
    serpent-xts        512b               N/A               N/A
    twofish-xts        512b               N/A               N/A
root@META-Flint:~#
All the packages listed in the OpenWrt Wiki / Disk Encryption, namely kmod-crypto-ecb, kmod-crypto-xts, kmod-crypto-seqiv, kmod-crypto-misc, kmod-crypto-user and cryptsetup, are present and were correctly installed via opkg:
root@META-Flint:~# opkg list_installed | grep kmod-crypto
kmod-crypto-acompress - 5.4.164-1
kmod-crypto-aead - 5.4.164-1
kmod-crypto-cbc - 5.4.164-1
kmod-crypto-crc32c - 5.4.164-1
kmod-crypto-ecb - 5.4.164-1
kmod-crypto-gf128 - 5.4.164-1
kmod-crypto-hash - 5.4.164-1
kmod-crypto-hmac - 5.4.164-1
kmod-crypto-manager - 5.4.164-1
kmod-crypto-misc - 5.4.164-1
kmod-crypto-null - 5.4.164-1
kmod-crypto-rng - 5.4.164-1
kmod-crypto-seqiv - 5.4.164-1
kmod-crypto-sha1 - 5.4.164-1
kmod-crypto-sha256 - 5.4.164-1
kmod-crypto-sha512 - 5.4.164-1
kmod-crypto-user - 5.4.164-1
kmod-crypto-xts - 5.4.164-1
root@META-Flint:~#
Despite the above, it seems that the kernel's crypto-related functions are not working correctly.
I understand that this is a non-standard configuration and may not be a high priority, but I hope this issue will be fixed by the GL.iNet staff.
P.S. I'm also a bit concerned that FW 4.7.0 has disappeared from Flint's firmware page, 4.6.8 is now listed as the latest, and Flint is not mentioned in the 4.8.x roadmap... Surely this doesn't mean it's heading for End-of-Life (EoL), right?
Firmware 4.7.0 is buggy, I had WiFi connection problems with several devices. Reverting to 4.6.8 solved the issues. It was supposed to be stable, but looks like it hadn't been tested enough.
Sorry, the compilation cryptsetup and required/related dependencies failed and failed to resolve.
Thank you for taking the time to investigate and get back to me.
I understand that the cryptsetup package is not a high priority, but it’s still disappointing to hear. Please let me know if there’s any chance it might be fixed in the future. I also hope that a wider range of OpenWRT packages will be supported on future GL.iNet products.
On a side note, as a resident of Japan, I’m very pleased that your products have the necessary technical certification (Giteki) required by local law and are available on Amazon.co.jp.
Please continue to make them available for the Japanese market—I’m looking forward to your future releases!
Sorry, I am not pretty sure.
If you do need these plugin packages, you can try to install Vanilla OpenWRT for AX1800.
Yep, we are very concerned about the Japanese market, thank you very much for your love and attention.
