GL-AX1800 main/guest VPN
Hi everyone,
I'm using a fantastic GL-AX1800 SN 8f1************8bf with firmware 4.7.0 release 8, as an access point, a Wireguard Surfsharck VPN, a main wireless network running WITH VPN, and a guest wireless network WITHOUT VPN.
My question is, can I somehow, while leaving the main network WITH VPN and the guest network WITHOUT VPN, declare some sites not to use the VPN? Currently, it works with the VLAN-based policy, but I'd like to use the domain-based or destination IP policy.
If I enable the domain-based or destination IP policy, everything works, but the guest wifi network also goes through the VPN. I don't want it to work like that... I want the domain-based or IP-based VPN policy and only the main wireless network with VPN, while the guest network works without VPN.
Do you think this is possible? Am I missing some detail or setting?!?
Thanks everyone...good luck.
That's functionality in 'VPN Policy' of firmware v4.8.x:
Please try to upgrade to v4.8.2 firmware for AX1800:
Hello and thanks for the replies. I'm not used to using unstable firmware versions; in general, I prefer stability to new features on any device. The specific settings I requested can hopefully wait for the new stable version. Thanks for your help.
