I’ve noticed a problem with my new GL-AX1800 router.
Internet seems to work fine but i do lose packets. For instance, teamviewer when helping a friend, drops the connection. Signal client on Linux, often sends a notification that is has no connection and my webcam doesn’t stay online either
First, my configuration:
ADSL connection max 10Mbps Orange.fr with livebox modem
Connected to GL-AX1800, with 1 meter utp cable.
Glinet v4.2.0
Openwrt21.01-snapshot r16399+159
Kernel 4.4.60
GL-AX1800 is in DMZ on the Livebox.
Installed on router: Adguardhome v0.107.29 as DNS resolver
Wireguard VPN server
PIA VPN client for several devices selected on MAC address.
I connected a Windows laptop directly to the port (using a cat6 cable) on the Livebox modem en executed a test using the site “test.vsee.com”
The results are shown in the first picture.
Then I connected the same laptop to a port on the GL-AX1800 and executed the test again.
These results are shown in the second picture.
During both tests, there was no or little traffic from other devices on my network.
Can someone help me why the traffic is dropped so much when it passes through the GL-AX1800 router?
Thank you very much,
Tom
