Today I received my AX1800 from Amazon Germany and I was really hyped!
Unfortunately, after the first start and updating, I relocated it to a better position. I plugged it in and waited for it to start. after 20 min neither the WiFi showed up, nor was I able to connect to it via LAN, also it does not show up in my main router. I then tried to reset it, but the light does not start flashing, it just stays on. I tried it at least 20 times. I also tried to reflash it via Uboot, but there is also the same problem, it won’t show up as if it was off (even though the light is on).
Only connect one cable to AX1800. Don’t connect more than one cable.
Hold the reset while powering on. Wait for the blue light flashes 5 times then turns white and stay on.
Release the finger
Manual set the IP address of your connected pc to 192.168.1.2
