Hi, i have owned this router for a few months now, and i keep getting disconnection issues. Im using wireguard VPN and DNS crypt. but they dont appear to be the problem. When i goto the logs i get lines of this error.
The router lite will be flashing, and i have to reboot it to get it working again. I have reset it several times. updated it without saving settings. so its on the latest firmware.
thanks.
Ok i have made the changes, for anyone else who needs to do this on linux for the first time.
I downloaded putty
Entered the router IP, then entered username and password and connected with the terminal
I was now at the root.
i typed in cd /etc and enter
then typed vi sysctl.conf and enter
this opens the file in the terminal,
I then pressed i so i could edit it and went to the value using the up and down keys.
Then while in edit mode i went to the line net.netfilter.nf_conntrack_max=65536 and changed it to that value.
Then I pressed escape.
Then typed :wq! and enter
that saved it. then i quit and rebooted the router.
