First problem:
Using Luci, no networks are showing GL-AXT-1800
But from the admin GUI, I can see the networks upon Scan in repeater option. IDK why?
Second problem:
I want to use luci to be able to connect to my uni (eduroam) network with the following parameters, and I can’t enter these values anywhere:
Security type: WPA2 Enterprise
Encryption method: AES
Key-Management: WPA-EAP
EAP (Phase 1): PEAP
Tunneled-EAP-Typ (Phase 2): MSCHAPv2
Root certificate: T-Telesec Global Root Class 2
Radius-Server: rad-net.zzzzz.edu
Identity: username@zzzzz.edu
Domain: zzzzz.edu
External/Anonymous Identity: yyyyy@zzzzz.edu
Password: Your password
The uni provide 3 certificates .pem and .crt format
Third problem:
MSCHAPv2 is not working with PEAP on GLinet router
Any hlep?
