I Just recieved my GL-AXT1800 & both of my Huawei 4g LTE dongles don’t work, the lights on the dongle light up as if its connected and in the GUI it states “tethering” however there is no internet connection/can’t resolve web address.
I have 2 x dongles a Huawei 8372-320 & a Huawei 8372-608.
Both of these dongles work in the GL-MV1000, GL-MT300N & GL-MT1300. They also both work on my PC.
I have changed the IP on the GL-AXT1800 to 192.168.9.1, 192.168.10.1 & 192.168.12.1 & still will not work.
I haven’t installed any packages on the GL-AXT1800 & the firmware is up to date
Figured it out, for some reason, both my Huawei dongles have an ip of 192.168.10.1 not 192.168.8.1, when i changed the address of the router to 192.168.7.1 it seems to work now.
So, after a few days with this, it seems to not be working, only 1 in 5 times when i reboot the router, it works, most of the time it doesn’t work. Both 4g dongles work straight away in the beryl and the brume.
from the kernel log
[43533.386348] usb 1-1: reset high-speed USB device number 10 using xhci-hcd
[43533.709135] cdc_ether 1-1:1.0 eth3: register ‘cdc_ether’ at usb-xhci-hcd.0.auto-1, CDC Ethernet Device, --.–.–.–.–.–
[43533.711175] cdc_ether 1-1:1.0 eth3: kevent 12 may have been dropped
[43533.716317] cdc_ether 1-1:1.0 eth3: kevent 11 may have been dropped
[43533.724309] cdc_ether 1-1:1.0 eth3: kevent 11 may have been dropped
