Hi, i'm trying to connect my GL-AXT1800 in an Tethering Android 5Ghz wifi but i can't see any 5Ghz SSID.
I read some post but all the solution doesn't work
Someone has the same issue?
Login the router SSH and execute the commands, to check the 5GHz APs:
logread
iwinfo
iwinfo wlan1 scan
Hi Bruce,
i try this but no SSID appear in my router
actually i have 2 android 5GHz active tethering but no one appeare in AXT1800 repeater
I'de read that AXT1800 can't repeat 5GHz chanel 149, that the one that android use
In android i can't change 5Ghz chanel, i hope that someone find a solution
Hi Bruce,
i find a way, i set country code to "driver defautl" and reboot, now i can see my android SSD
Thanks
