I have performed the factor reset on my GL-AXT1800 router
I am able to connect to the WIFI with the default WIFI password, and am able to get to login screen at 192.168.8.1, however, I am unable to log in successfully.
I tried using the same default wifi password as the Admin password. I also tried “admin” and “Admin”. I even tried “goodlife”.
If you are getting a login screen then the factory reset has not completed correctly. If it had you would be asked for your Language and then new password when you attach.
This was the page that I used to reset it. I performed it twice before I posted. I guess third times the charm. When I released the button this time, the language screen came up, followed by setting the password dialog.
Thanks! This seems to have been the problem. I did reset it twice following the instructions before I posted. Perhaps there should be some kind of visual confirmation that the reset worked (or failed). Can the LED blink pattern be used? Can the LED color change?
