GL-AXT1800 crashed
Hi, new here, really like the router so far, but never had a router on stable firmware crash on me for a long time. Got a MikroTik router with the same chipset, that has also never crashed so far… :sweat_smile: Bought it a few days ago from Amazon. Also mailed support including full logs.
Router was connected with WAN ethernet (DHCP), running one single WireGuard tunnel, and Adguard home.
Firmware info is Version 4.2.0, Firmware Type release3, Compile Time 2023-03-10 0:37:13(UTC+08:00)
It crashed with 2 MacBooks and an iPhone connected, WPA3 PSK SSID, same name for 2.4/5G.
Any help with this? Should I try a different build? Saw there are beta builds as well as one with a 5.x kernel.
Log:
type or pasLog Entry 1 (at position 0)
<4>[ 8804.940737] CPU: 1 PID: 121 Comm: kworker/1:1 Not tainted 4.4.60 #0
<4>[ 8804.941092] Hardware name: Generic DT based system
<4>[ 8804.947174] Workqueue: events rproc_crash_handler_work
<4>[ 8804.957141] task: 9dec5e80 ti: 9d922000 task.ti: 9d922000
<4>[ 8804.957280] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
<4>[ 8804.962653] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
<4>[ 8804.968699] pc : [<7f914064>]    lr : [<7f916764>]    psr: 60000013
<4>[ 8804.968699] sp : 9d923e28  ip : 00000000  fp : 9d816428
<4>[ 8804.975303] r10: 8083a520  r9 : 9d816664  r8 : 00000000
<4>[ 8804.986491] r7 : 8075fde0  r6 : 9e5af610  r5 : 8075fde0  r4 : 9a85092c
<4>[ 8804.991700] r3 : 00000000  r2 : dc8ba63c  r1 : 9eb4a324  r0 : 0000007b
<4>[ 8804.998300] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
<4>[ 8805.004810] Control: 10c0383d  Table: 5cb6006a  DAC: 00000055
<0>[ 8805.012013] Process kworker/1:1 (pid: 121, stack limit = 0x9d922210)
<0>[ 8805.017916] Stack: (0x9d923e28 to 0x9d924000)
<0>[ 8805.024339] 3e20:                   00000000 9a85192c 00000000 fffffffd 00000000 80044da0
<0>[ 8805.028600] 3e40: 8087d520 00000000 8075fde0 ffffffff 9d816428 80045094 00000000 9d923e6c
<0>[ 8805.036760] 3e60: 00000000 9d816778 9d816604 00000001 9d816400 800450c8 00000000 803572ec
<0>[ 8805.044920] 3e80: 9d81662c 8044c40c 9d81662c 9d816664 9d816400 9d81662c 9d8165c0 8044df58
<0>[ 8805.053079] 3ea0: 00000001 80357180 8073f63c 8075eeec 9d8074c0 00000000 c2ec8ac1 9d81662c
<0>[ 8805.061238] 3ec0: 9d816664 00000003 9d81662c 9d8165c0 9d816664 8083a520 9eb4cb40 8044e290
<0>[ 8805.069398] 3ee0: 8044e164 9d81662c 9df42800 9eb4cb40 9eb50000 00000000 00000000 8083a520
<0>[ 8805.077559] 3f00: 9eb4cb40 8003ed30 9eb4cb40 9eb4cb40 00000008 9df42800 9df42818 9eb4cb40
<0>[ 8805.085717] 3f20: 00000008 9eb4cb54 9d922000 8083a520 9eb4cb40 8003f1b0 80836100 9df42800
<0>[ 8805.093877] 3f40: 8003eec8 00000000 9df43380 9df42800 8003eec8 00000000 00000000 00000000
<0>[ 8805.102036] 3f60: 00000000 8004428c 0224a00c 00000000 2e80a882 9df42800 00000000 00000000
<0>[ 8805.110196] 3f80: 9d923f80 9d923f80 00000000 00000000 9d923f90 9d923f90 9d923fac 9df43380
<0>[ 8805.118356] 3fa0: 8004419c 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
<0>[ 8805.126515] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<0>[ 8805.134676] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 84800828 58015405
<4>[ 8805.142966] [<7f914064>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044da0>] (notifier_call_chain+0x2c/0x70)
<4>[ 8805.151003] [<80044da0>] (notifier_call_chain) from [<80045094>] (__blocking_notifier_call_chain+0x48/0x64)
<4>[ 8805.161242] [<80045094>] (__blocking_notifier_call_chain) from [<800450c8>] (blocking_notifier_call_chain+0x18/0x20)
<4>[ 8805.170796] [<800450c8>] (blocking_notifier_call_chain) from [<8044c40c>] (rproc_stop+0x2c/0xc4)
<4>[ 8805.181555] [<8044c40c>] (rproc_stop) from [<8044df58>] (rproc_trigger_recovery+0x4c/0x258)
<4>[ 8805.190320] [<8044df58>] (rproc_trigger_recovery) from [<8044e290>] (rproc_crash_handler_work+0x12c/0x1bc)
<4>[ 8805.198397] [<8044e290>] (rproc_crash_handler_work) from [<8003ed30>] (process_one_work+0x220/0x3b8)
<4>[ 8805.208118] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
<4>[ 8805.217402] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
<4>[ 8805.225475] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
<0>[ 8805.232593] Code: eb2550eb e3500000 0affffe9 ea000000 (e7f001f2)
<4>[ 8805.239799] ---[ end trace ba8f994b62103926 ]---
<0>[ 8805.250280] Kernel panic - not syncing: Fatal exception
<2>[ 8805.250645] CPU0: stopping
<4>[ 8805.255587] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.4.60 #0
<4>[ 8805.258368] Hardware name: Generic DT based system
<4>[ 8805.265577] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 8805.270269] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 8805.278165] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 8805.285197] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 8805.292748] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 8805.300123] Exception stack(0x80835f50 to 0x80835f98)
<4>[ 8805.307673] 5f40:                                     00000001 00000000 00000000 8000b400
<4>[ 8805.312713] 5f60: 80834000 808364a0 806d2e38 00000000 00000000 8082f30c 80835fa8 808364a8
<4>[ 8805.320873] 5f80: 60000013 80835fa0 80019394 80019398 60000013 ffffffff
<4>[ 8805.329032] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 8805.335459] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 8805.343099] [<80063664>] (cpu_startup_entry) from [<807f7d28>] (start_kernel+0x430/0x43c)
<2>[ 8805.351167] CPU2: stopping
<4>[ 8805.359404] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D         4.4.60 #0
<4>[ 8805.362014] Hardware name: Generic DT based system
<4>[ 8805.369220] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 8805.373913] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 8805.381809] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 8805.388841] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 8805.396393] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 8805.403768] Exception stack(0x9e48df88 to 0x9e48dfd0)
<4>[ 8805.411319] df80:                   00000001 00000000 00000000 8000b400 9e48c000 808364a0
<4>[ 8805.416360] dfa0: 806d2e38 00000000 00000000 8082f30c 9e48dfe0 808364a8 9a89fec9 9e48dfd8
<4>[ 8805.424517] dfc0: 80019394 80019398 60000013 ffffffff
<4>[ 8805.432674] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 8805.437713] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 8805.445181] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[ 8805.453246] CPU3: stopping
<4>[ 8805.460099] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D         4.4.60 #0
<4>[ 8805.462881] Hardware name: Generic DT based system
<4>[ 8805.470088] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 8805.474779] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 8805.482679] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 8805.489710] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 8805.497261] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 8805.504637] Exception stack(0x9e48ff88 to 0x9e48ffd0)
<4>[ 8805.512187] ff80:                   00000001 00000000 00000000 8000b400 9e48e000 808364a0
<4>[ 8805.517227] ffa0: 806d2e38 00000000 00000000 8082f30c 9e48ffe0 808364a8 00000000 9e48ffd8
<4>[ 8805.525386] ffc0: 80019394 80019398 60000013 ffffffff
<4>[ 8805.533542] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 8805.538582] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 8805.546047] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<0>[ 8805.554121] The reading for sensor 4 is 0x002042ab
<0>[ 8805.560970] The reading for sensor 5 is 0x002052af
<0>[ 8805.565831] The reading for sensor 7 is 0x002072a8
<0>[ 8805.570653] Couldn't get reading for sensor 8
<0>[ 8805.575380] The reading for sensor 13 is 0x0022d2af
<0>[ 8805.579855] Couldn't get reading for sensor 14
<0>[ 8805.584495] The reading for sensor 15 is 0x0020f2b2
Log Entry 2 (at position 1)
<4>[ 6364.011450] CPU: 1 PID: 121 Comm: kworker/1:1 Not tainted 4.4.60 #0
<4>[ 6364.011801] Hardware name: Generic DT based system
<4>[ 6364.017886] Workqueue: events rproc_crash_handler_work
<4>[ 6364.027851] task: 9dec5e80 ti: 9d922000 task.ti: 9d922000
<4>[ 6364.027989] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
<4>[ 6364.033361] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
<4>[ 6364.039408] pc : [<7f914064>]    lr : [<7f916764>]    psr: 60000013
<4>[ 6364.039408] sp : 9d923e28  ip : 00000000  fp : 9d816428
<4>[ 6364.046014] r10: 8083a520  r9 : 9d816664  r8 : 00000000
<4>[ 6364.057200] r7 : 8075fde0  r6 : 9e5af610  r5 : 8075fde0  r4 : 9a86092c
<4>[ 6364.062411] r3 : 00000000  r2 : dc8ba63c  r1 : 9eb4a324  r0 : 0000007b
<4>[ 6364.069009] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
<4>[ 6364.075521] Control: 10c0383d  Table: 5d56806a  DAC: 00000055
<0>[ 6364.082722] Process kworker/1:1 (pid: 121, stack limit = 0x9d922210)
<0>[ 6364.088625] Stack: (0x9d923e28 to 0x9d924000)
<0>[ 6364.095048] 3e20:                   8083a520 9a86192c 00000000 fffffffd 00000000 80044da0
<0>[ 6364.099309] 3e40: 8087d520 00000000 8075fde0 ffffffff 9d816428 80045094 00000000 9d923e6c
<0>[ 6364.107468] 3e60: 00000000 9d816778 9d816604 00000001 9d816400 800450c8 00000000 803572ec
<0>[ 6364.115628] 3e80: 9d81662c 8044c40c 9d81662c 9d816664 9d816400 9d81662c 9d8165c0 8044df58
<0>[ 6364.123788] 3ea0: 00000001 80357180 8073f63c 8075eeec 9d8074c0 00000000 64025a92 9d81662c
<0>[ 6364.131948] 3ec0: 9d816664 00000003 9d81662c 9d8165c0 9d816664 8083a520 9eb4cb40 8044e290
<0>[ 6364.140107] 3ee0: 8044e164 9d81662c 9df42800 9eb4cb40 9eb50000 00000000 00000000 8083a520
<0>[ 6364.148268] 3f00: 9eb4cb40 8003ed30 9eb4cb40 9eb4cb40 00000008 9df42800 9df42818 9eb4cb40
<0>[ 6364.156426] 3f20: 00000008 9eb4cb54 9d922000 8083a520 9eb4cb40 8003f1b0 80836100 9df42800
<0>[ 6364.164586] 3f40: 8003eec8 00000000 9df43380 9df42800 8003eec8 00000000 00000000 00000000
<0>[ 6364.172747] 3f60: 00000000 8004428c 00000000 00000000 00000000 9df42800 00000000 00000000
<0>[ 6364.180906] 3f80: 9d923f80 9d923f80 00000000 00000000 9d923f90 9d923f90 9d923fac 9df43380
<0>[ 6364.189065] 3fa0: 8004419c 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
<0>[ 6364.197226] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<0>[ 6364.205385] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
<4>[ 6364.213677] [<7f914064>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044da0>] (notifier_call_chain+0x2c/0x70)
<4>[ 6364.221714] [<80044da0>] (notifier_call_chain) from [<80045094>] (__blocking_notifier_call_chain+0x48/0x64)
<4>[ 6364.231952] [<80045094>] (__blocking_notifier_call_chain) from [<800450c8>] (blocking_notifier_call_chain+0x18/0x20)
<4>[ 6364.241506] [<800450c8>] (blocking_notifier_call_chain) from [<8044c40c>] (rproc_stop+0x2c/0xc4)
<4>[ 6364.252265] [<8044c40c>] (rproc_stop) from [<8044df58>] (rproc_trigger_recovery+0x4c/0x258)
<4>[ 6364.261029] [<8044df58>] (rproc_trigger_recovery) from [<8044e290>] (rproc_crash_handler_work+0x12c/0x1bc)
<4>[ 6364.269108] [<8044e290>] (rproc_crash_handler_work) from [<8003ed30>] (process_one_work+0x220/0x3b8)
<4>[ 6364.278826] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
<4>[ 6364.288112] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
<4>[ 6364.296184] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
<0>[ 6364.303301] Code: eb2550eb e3500000 0affffe9 ea000000 (e7f001f2)
<4>[ 6364.310507] ---[ end trace e585dcf880d3fc20 ]---
<0>[ 6364.321002] Kernel panic - not syncing: Fatal exception
<2>[ 6364.321352] CPU2: stopping
<4>[ 6364.326296] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D         4.4.60 #0
<4>[ 6364.329077] Hardware name: Generic DT based system
<4>[ 6364.336288] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 6364.340978] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 6364.348874] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 6364.355905] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 6364.363457] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 6364.370833] Exception stack(0x9e48df88 to 0x9e48dfd0)
<4>[ 6364.378383] df80:                   00000001 00000000 00000000 8000b400 9e48c000 808364a0
<4>[ 6364.383424] dfa0: 806d2e38 00000000 00000000 8082f30c 9e48dfe0 808364a8 60000013 9e48dfd8
<4>[ 6364.391581] dfc0: 80019394 80019398 60000013 ffffffff
<4>[ 6364.399737] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 6364.404780] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 6364.412245] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[ 6364.420311] CPU0: stopping
<4>[ 6364.427163] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.4.60 #0
<4>[ 6364.429945] Hardware name: Generic DT based system
<4>[ 6364.437152] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 6364.441845] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 6364.449742] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 6364.456774] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 6364.464324] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 6364.471701] Exception stack(0x80835f50 to 0x80835f98)
<4>[ 6364.479250] 5f40:                                     00000001 00000000 00000000 8000b400
<4>[ 6364.484292] 5f60: 80834000 808364a0 806d2e38 00000000 00000000 8082f30c 80835fa8 808364a8
<4>[ 6364.492451] 5f80: 60000013 80835fa0 80019394 80019398 60000013 ffffffff
<4>[ 6364.500608] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 6364.507035] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 6364.514676] [<80063664>] (cpu_startup_entry) from [<807f7d28>] (start_kernel+0x430/0x43c)
<2>[ 6364.522745] CPU3: stopping
<4>[ 6364.530981] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D         4.4.60 #0
<4>[ 6364.533591] Hardware name: Generic DT based system
<4>[ 6364.540798] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 6364.545489] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 6364.553388] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 6364.560420] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 6364.567970] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 6364.575347] Exception stack(0x9e48ff88 to 0x9e48ffd0)
<4>[ 6364.582895] ff80:                   00000001 00000000 00000000 8000b400 9e48e000 808364a0
<4>[ 6364.587938] ffa0: 806d2e38 00000000 00000000 8082f30c 9e48ffe0 808364a8 9e48ff80 9e48ffd8
<4>[ 6364.596096] ffc0: 80019394 80019398 60000013 ffffffff
<4>[ 6364.604250] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 6364.609290] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 6364.616757] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<0>[ 6364.624876] Couldn't get reading for sensor 4
<0>[ 6364.631679] The reading for sensor 5 is 0x002052c3
<0>[ 6364.636194] The reading for sensor 7 is 0x002072b2
<0>[ 6364.640881] The reading for sensor 8 is 0x002082af
<0>[ 6364.645655] The reading for sensor 13 is 0x0022d2b5
<0>[ 6364.650429] The reading for sensor 14 is 0x0020e2af
<0>[ 6364.655251] Couldn't get reading for sensor 15
Log Entry 3 (at position 2)
<4>[ 9596.583678] CPU: 1 PID: 121 Comm: kworker/1:1 Not tainted 4.4.60 #0
<4>[ 9596.584032] Hardware name: Generic DT based system
<4>[ 9596.590115] Workqueue: events rproc_crash_handler_work
<4>[ 9596.600082] task: 9dec5e80 ti: 9d92a000 task.ti: 9d92a000
<4>[ 9596.600221] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
<4>[ 9596.605592] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
<4>[ 9596.611640] pc : [<7f914064>]    lr : [<7f916764>]    psr: 60000013
<4>[ 9596.611640] sp : 9d92be28  ip : 00000000  fp : 9d81e428
<4>[ 9596.618244] r10: 8083a520  r9 : 9d81e664  r8 : 00000000
<4>[ 9596.629431] r7 : 8075fde0  r6 : 9e5af610  r5 : 8075fde0  r4 : 9a86092c
<4>[ 9596.634642] r3 : 00000000  r2 : dc8ba63c  r1 : 9eb4a324  r0 : 0000007b
<4>[ 9596.641240] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
<4>[ 9596.647750] Control: 10c0383d  Table: 57eb406a  DAC: 00000055
<0>[ 9596.654953] Process kworker/1:1 (pid: 121, stack limit = 0x9d92a210)
<0>[ 9596.660856] Stack: (0x9d92be28 to 0x9d92c000)
<0>[ 9596.667279] be20:                   00000000 9a86192c 00000000 fffffffd 00000000 80044da0
<0>[ 9596.671539] be40: 8087d520 00000000 8075fde0 ffffffff 9d81e428 80045094 00000000 9d92be6c
<0>[ 9596.679700] be60: 00000000 9d81e778 9d81e604 00000001 9d81e400 800450c8 00000000 803572ec
<0>[ 9596.687860] be80: 9d81e62c 8044c40c 9d81e62c 9d81e664 9d81e400 9d81e62c 9d81e5c0 8044df58
<0>[ 9596.696019] bea0: 00000001 80357180 8073f63c 8075eeec 9d80f4c0 00000000 0c49ed66 9d81e62c
<0>[ 9596.704179] bec0: 9d81e664 00000003 9d81e62c 9d81e5c0 9d81e664 8083a520 9eb4cb40 8044e290
<0>[ 9596.712338] bee0: 8044e164 9d81e62c 9df0f800 9eb4cb40 9eb50000 00000000 00000000 8083a520
<0>[ 9596.720498] bf00: 9eb4cb40 8003ed30 9eb4cb40 9eb4cb40 00000008 9df0f800 9df0f818 9eb4cb40
<0>[ 9596.728659] bf20: 00000008 9eb4cb54 9d92a000 8083a520 9eb4cb40 8003f1b0 80836100 9df0f800
<0>[ 9596.736818] bf40: 8003eec8 00000000 9df0e400 9df0f800 8003eec8 00000000 00000000 00000000
<0>[ 9596.744976] bf60: 00000000 8004428c 00000000 00000000 00000000 9df0f800 00000000 00000000
<0>[ 9596.753138] bf80: 9d92bf80 9d92bf80 00000000 00000000 9d92bf90 9d92bf90 9d92bfac 9df0e400
<0>[ 9596.761296] bfa0: 8004419c 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
<0>[ 9596.769457] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<0>[ 9596.777616] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
<4>[ 9596.785907] [<7f914064>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044da0>] (notifier_call_chain+0x2c/0x70)
<4>[ 9596.793944] [<80044da0>] (notifier_call_chain) from [<80045094>] (__blocking_notifier_call_chain+0x48/0x64)
<4>[ 9596.804184] [<80045094>] (__blocking_notifier_call_chain) from [<800450c8>] (blocking_notifier_call_chain+0x18/0x20)
<4>[ 9596.813736] [<800450c8>] (blocking_notifier_call_chain) from [<8044c40c>] (rproc_stop+0x2c/0xc4)
<4>[ 9596.824497] [<8044c40c>] (rproc_stop) from [<8044df58>] (rproc_trigger_recovery+0x4c/0x258)
<4>[ 9596.833262] [<8044df58>] (rproc_trigger_recovery) from [<8044e290>] (rproc_crash_handler_work+0x12c/0x1bc)
<4>[ 9596.841338] [<8044e290>] (rproc_crash_handler_work) from [<8003ed30>] (process_one_work+0x220/0x3b8)
<4>[ 9596.851058] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
<4>[ 9596.860343] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
<4>[ 9596.868416] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
<0>[ 9596.875532] Code: eb2550eb e3500000 0affffe9 ea000000 (e7f001f2)
<4>[ 9596.882740] ---[ end trace 70d7c11f08fc1cb8 ]---
<0>[ 9596.893225] Kernel panic - not syncing: Fatal exception
<2>[ 9596.893585] CPU0: stopping
<4>[ 9596.898528] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.4.60 #0
<4>[ 9596.901309] Hardware name: Generic DT based system
<4>[ 9596.908519] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 9596.913209] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 9596.921106] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 9596.928138] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 9596.935688] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 9596.943064] Exception stack(0x80835f50 to 0x80835f98)
<4>[ 9596.950613] 5f40:                                     00000001 00000000 00000000 8000b400
<4>[ 9596.955655] 5f60: 80834000 808364a0 806d2e38 00000000 00000000 8082f30c 80835fa8 808364a8
<4>[ 9596.963813] 5f80: 60000013 80835fa0 80019394 80019398 60000013 ffffffff
<4>[ 9596.971971] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 9596.978399] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 9596.986040] [<80063664>] (cpu_startup_entry) from [<807f7d28>] (start_kernel+0x430/0x43c)
<2>[ 9596.994107] CPU3: stopping
<4>[ 9597.002345] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D         4.4.60 #0
<4>[ 9597.004955] Hardware name: Generic DT based system
<4>[ 9597.012160] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 9597.016853] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 9597.024751] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 9597.031781] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 9597.039335] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 9597.046710] Exception stack(0x9e48ff88 to 0x9e48ffd0)
<4>[ 9597.054259] ff80:                   00000001 00000000 00000000 8000b400 9e48e000 808364a0
<4>[ 9597.059301] ffa0: 806d2e38 00000000 00000000 8082f30c 9e48ffe0 808364a8 9e48ff80 9e48ffd8
<4>[ 9597.067459] ffc0: 80019394 80019398 60000013 ffffffff
<4>[ 9597.075613] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 9597.080654] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 9597.088121] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[ 9597.096187] CPU2: stopping
<4>[ 9597.103039] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D         4.4.60 #0
<4>[ 9597.105822] Hardware name: Generic DT based system
<4>[ 9597.113030] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[ 9597.117721] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[ 9597.125618] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[ 9597.132650] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[ 9597.140202] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[ 9597.147578] Exception stack(0x9e48df88 to 0x9e48dfd0)
<4>[ 9597.155127] df80:                   00000001 00000000 00000000 8000b400 9e48c000 808364a0
<4>[ 9597.160169] dfa0: 806d2e38 00000000 00000000 8082f30c 9e48dfe0 808364a8 00000000 9e48dfd8
<4>[ 9597.168325] dfc0: 80019394 80019398 60000013 ffffffff
<4>[ 9597.176483] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[ 9597.181521] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[ 9597.188987] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<0>[ 9597.197061] The reading for sensor 4 is 0x002042af
<0>[ 9597.203910] The reading for sensor 5 is 0x002052b2
<0>[ 9597.208771] The reading for sensor 7 is 0x002072ab
<0>[ 9597.213546] The reading for sensor 8 is 0x002082ab
<0>[ 9597.218321] The reading for sensor 13 is 0x0022d2b2
<0>[ 9597.223142] Couldn't get reading for sensor 14
<0>[ 9597.227868] The reading for sensor 15 is 0x0020f2b2
I’m hearing a lot of issues with 4.2.0 firmwares in general on all devices. I’d stick with 4.1.0 or lower for right now.
Thanks @pabzter , highly appreciated!
Noob here, can I just downgrade it and keep settings, or should I reset and start fresh?
I always recommend a fresh start unless you have a very tedious or specific setup where that’s problematic.
Awesome, thanks @pabzter .
I’ll wait a bit to see if the devs / support need anything else from the existing setup to debug and fix, and afterwards I’ll downgrade.
Support directed me here, have successfully downgraded WiFi.
Monitoring stability now.
