GL-AXT1800 crashing every 2 or 3 days
My Slate AX travel router (firmware v4.4.6) keeps chrashing every 2 to 3 days. It seems related to Wi-Fi. When I am using only ethernet it is more stable but as soon as I enable 5GHz, with only a couple of devices connecting to it, it crashes randomly after a while. It does not seem to last longer than 3 days without a restart.
It seems to be related to qcom-q6v5-wcss-pil cd00000.qcom_q6v5_wcss.
This is the last Crash Log:
 nls_iso8859_1 nls_cp437 sha1_generic md5 des_generic cts mtdoops uas usb_storage gl_fan_driver xhci_plat_hcd xhci_pci xhci_hcd dwc3 dwc3_qcom dbm uhci_hcd ohci_platform ohci_hcd phy_msm_ssusb_qmp phy_msm_qusb ehci_platform sd_mod scsi_mod ehci_hcd gpio_button_hotplug gl_sdk4_tertf gl_sdk4_black_white_list usbcore nls_base usb_common mii gl_sdk4_hw_info
<4>[245096.893478] CPU: 1 PID: 121 Comm: kworker/1:1 Not tainted 4.4.60 #0
<4>[245096.893834] Hardware name: Generic DT based system
<4>[245096.900265] Workqueue: events rproc_crash_handler_work
<4>[245096.910057] task: 9dee5e80 ti: 9d92a000 task.ti: 9d92a000
<4>[245096.910284] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
<4>[245096.915656] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
<4>[245096.922135] pc : [<7f91a064>]    lr : [<7f91c764>]    psr: 60000013
<4>[245096.922135] sp : 9d92be28  ip : 00000000  fp : 9d81e428
<4>[245096.928480] r10: 8083a520  r9 : 9d81e664  r8 : 00000000
<4>[245096.940100] r7 : 8075fde0  r6 : 9e5af610  r5 : 8075fde0  r4 : 9a86092c
<4>[245096.945484] r3 : 00000000  r2 : dc8ba63c  r1 : 9eb4a324  r0 : 0000007d
<4>[245096.951822] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
<4>[245096.958420] Control: 10c0383d  Table: 5bbb006a  DAC: 00000055
<0>[245096.966055] Process kworker/1:1 (pid: 121, stack limit = 0x9d92a210)
<0>[245096.971700] Stack: (0x9d92be28 to 0x9d92c000)
<0>[245096.978209] be20:                   9d92be88 9a86192c 00000000 fffffffd 00000000 80044da0
<0>[245096.982556] be40: 8087d520 00000000 8075fde0 ffffffff 9d81e428 80045094 00000000 9d92be6c
<0>[245096.990803] be60: 60000013 9d81e778 9d81e604 00000001 9d81e400 800450c8 00000000 803572ec
<0>[245096.999050] be80: 9d81e62c 8044c40c 9d81e62c 9d81e664 9d81e400 9d81e62c 9d81e5c0 8044df58
<0>[245097.007295] bea0: 00000001 80357180 8073f63c 8075eeec 9d80f4c0 00000000 da69dd50 9d81e62c
<0>[245097.015542] bec0: 9d81e664 00000003 9d81e62c 9d81e5c0 9d81e664 8083a520 9eb4cb40 8044e290
<0>[245097.023789] bee0: 8044e164 9d81e62c 9ddc1500 9eb4cb40 9eb50000 00000000 00000000 8083a520
<0>[245097.032036] bf00: 9eb4cb40 8003ed30 9eb4cb40 9eb4cb40 00000008 9ddc1500 9ddc1518 9eb4cb40
<0>[245097.040281] bf20: 00000008 9eb4cb54 9d92a000 8083a520 9eb4cb40 8003f1b0 80836100 9ddc1500
<0>[245097.048528] bf40: 8003eec8 00000000 9ddc0400 9ddc1500 8003eec8 00000000 00000000 00000000
<0>[245097.056774] bf60: 00000000 8004428c 00000000 00000000 00000000 9ddc1500 00000000 00000000
<0>[245097.065022] bf80: 9d92bf80 9d92bf80 00000000 00000000 9d92bf90 9d92bf90 9d92bfac 9ddc0400
<0>[245097.073267] bfa0: 8004419c 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
<0>[245097.081515] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<0>[245097.089760] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
<4>[245097.098141] [<7f91a064>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044da0>] (notifier_call_chain+0x2c/0x70)
<4>[245097.106262] [<80044da0>] (notifier_call_chain) from [<80045094>] (__blocking_notifier_call_chain+0x48/0x64)
<4>[245097.116589] [<80045094>] (__blocking_notifier_call_chain) from [<800450c8>] (blocking_notifier_call_chain+0x18/0x20)
<4>[245097.126575] [<800450c8>] (blocking_notifier_call_chain) from [<8044c40c>] (rproc_stop+0x2c/0xc4)
<4>[245097.137075] [<8044c40c>] (rproc_stop) from [<8044df58>] (rproc_trigger_recovery+0x4c/0x258)
<4>[245097.145928] [<8044df58>] (rproc_trigger_recovery) from [<8044e290>] (rproc_crash_handler_work+0x12c/0x1bc)
<4>[245097.154437] [<8044e290>] (rproc_crash_handler_work) from [<8003ed30>] (process_one_work+0x220/0x3b8)
<4>[245097.163896] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
<4>[245097.173269] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
<4>[245097.181427] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
<0>[245097.188632] Code: eb2538eb e3500000 0affffe9 ea000000 (e7f001f2)
<4>[245097.195926] ---[ end trace 6c70fbc4ed8d4537 ]---
<0>[245097.206776] Kernel panic - not syncing: Fatal exception
<2>[245097.206945] CPU0: stopping
<4>[245097.212322] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.4.60 #0
<4>[245097.214842] Hardware name: Generic DT based system
<4>[245097.222142] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[245097.226917] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[245097.234900] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[245097.242017] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[245097.249657] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[245097.257119] Exception stack(0x80835f50 to 0x80835f98)
<4>[245097.264754] 5f40:                                     00000001 00000000 00000000 8000b400
<4>[245097.269884] 5f60: 80834000 808364a0 806d2e38 00000000 00000000 8082f30c 80835fa8 808364a8
<4>[245097.278128] 5f80: 60000013 80835fa0 80019394 80019398 60000013 ffffffff
<4>[245097.286374] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[245097.293236] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[245097.300616] [<80063664>] (cpu_startup_entry) from [<807f7d28>] (start_kernel+0x430/0x43c)
<2>[245097.308769] CPU2: stopping
<4>[245097.317094] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D         4.4.60 #0
<4>[245097.319791] Hardware name: Generic DT based system
<4>[245097.327083] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[245097.331862] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[245097.339847] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[245097.346965] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[245097.354603] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[245097.362065] Exception stack(0x9e48df88 to 0x9e48dfd0)
<4>[245097.369702] df80:                   00000001 00000000 00000000 8000b400 9e48c000 808364a0
<4>[245097.374831] dfa0: 806d2e38 00000000 00000000 8082f30c 9e48dfe0 808364a8 9e48df80 9e48dfd8
<4>[245097.383075] dfc0: 80019394 80019398 60000013 ffffffff
<4>[245097.391318] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[245097.396444] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[245097.403998] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[245097.412151] CPU3: stopping
<4>[245097.419438] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D         4.4.60 #0
<4>[245097.421960] Hardware name: Generic DT based system
<4>[245097.429254] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[245097.434031] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[245097.442017] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[245097.449135] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[245097.456773] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[245097.464235] Exception stack(0x9e48ff88 to 0x9e48ffd0)
<4>[245097.471873] ff80:                   00000001 00000000 00000000 8000b400 9e48e000 808364a0
<4>[245097.477000] ffa0: 806d2e38 00000000 00000000 8082f30c 9e48ffe0 808364a8 60000013 9e48ffd8
<4>[245097.485244] ffc0: 80019394 80019398 60000013 ffffffff
<4>[245097.493489] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[245097.498614] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[245097.506167] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<0>[245097.514328] The reading for sensor 4 is 0x002042bb
<0>[245097.521659] Couldn't get reading for sensor 5
<0>[245097.526212] The reading for sensor 7 is 0x002072b7
<0>[245097.530726] The reading for sensor 8 is 0x002082b4
<0>[245097.535501] The reading for sensor 13 is 0x0022d2c1
<0>[245097.540409] Couldn't get reading for sensor 14
<0>[245097.545569] The reading for sensor 15 is 0x0020f2bb
And this is from the system log:
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] qcom-q6v5-wcss-pil cd00000.qcom_q6v5_wcss: fatal error received:
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] QC Image Version: QC_IMAGE_VERSION_STRING=WLAN.HK.2.6.0.1-00861-QCAHKSWPL_SILICONZ-1
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] Image Variant : IMAGE_VARIANT_STRING=6018.wlanfw.evalQ
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881]     :Excep  :0 Exception detectedparam0 :zero, param1 :zero, param2 :zero.
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] Thread ID      : 0x00000067  Thread name    : WLAN TAC0  Process ID     : 0
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] Register:
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] SP : 0x4ba85990
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] FP : 0x4ba859a8
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] PC : 0x4ad7af50
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] SSR : 0x00000003
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] BADVA : 0x00000012
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] LR : 0x4ade1dc4
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] Stack Dump
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] from : 0x4ba85990
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.087881] to   : 0x4ba86030
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.136040] remoteproc remoteproc0: crash detected in cd00000.qcom_q6v5_wcss: type fatal error
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.159220] remoteproc remoteproc0: handling crash #1 in cd00000.qcom_q6v5_wcss
Sun Dec 10 19:16:16 2023 kern.err kernel: [245084.167091] remoteproc remoteproc0: recovering cd00000.qcom_q6v5_wcss
Sun Dec 10 19:16:20 2023 kern.warn kernel: [245087.705398] ath11k c000000.wifi: bss channel survey timed out
Sun Dec 10 19:16:26 2023 kern.err kernel: [245094.165335]  9eb82650:9eb82ab0: intent request timed out
Sun Dec 10 19:16:26 2023 kern.err kernel: [245094.165367] qcom_glink_ssr 9eb82650:9eb82ab0.glink_ssr.-1.-1: failed to send cleanup message
Sun Dec 10 19:16:27 2023 kern.err kernel: [245095.165328] qcom_glink_ssr 9eb82650:9eb82ab0.glink_ssr.-1.-1: timeout waiting for cleanup done message
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.165379] ath11k c000000.wifi: ATH11K Driver Stats
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.165379] Backpressure Stats
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.165379] ==================
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.165379] No Ring Backpressure stats received
Sun Dec 10 19:16:27 2023 kern.err kernel: [245095.173556] ath11k c000000.wifi: Last interrupt received for each CE:
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.195255] ath11k c000000.wifi: CE_id 0 pipe_num 0 245074680ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.200892] ath11k c000000.wifi: ce_time_dur_100US,	 last_sched_before  245074690ms,	 tot_sched_cnt                    4,	 last_exec_before  245074690ms,	 tot_exec_cnt                    4
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.211791] ath11k c000000.wifi: ce_time_dur_200US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.228583] ath11k c000000.wifi: ce_time_dur_300US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.245987] ath11k c000000.wifi: ce_time_dur_400US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.262032] ath11k c000000.wifi: ce_time_dur_500US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:27 2023 kern.info kernel: [245095.279016] ath11k c000000.wifi: CE_id 1 pipe_num 1 11400ms before, sched_delay_gt_500US 322, exec_delay_gt_500US 4
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.295701] ath11k c000000.wifi: ce_time_dur_100US,	 last_sched_before      11420ms,	 tot_sched_cnt              3975178,	 last_exec_before      11420ms,	 tot_exec_cnt              3988772
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.306285] ath11k c000000.wifi: ce_time_dur_200US,	 last_sched_before      23150ms,	 tot_sched_cnt                10184,	 last_exec_before   29660890ms,	 tot_exec_cnt                   16
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.323039] ath11k c000000.wifi: ce_time_dur_300US,	 last_sched_before      23140ms,	 tot_sched_cnt                 2183,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.339876] ath11k c000000.wifi: ce_time_dur_400US,	 last_sched_before      23300ms,	 tot_sched_cnt                  778,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.356722] ath11k c000000.wifi: ce_time_dur_500US,	 last_sched_before      23090ms,	 tot_sched_cnt                  148,	 last_exec_before  187197300ms,	 tot_exec_cnt                    1
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.373557] ath11k c000000.wifi: CE_id 2 pipe_num 2 11540ms before, sched_delay_gt_500US 7, exec_delay_gt_500US 6
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.390389] ath11k c000000.wifi: ce_time_dur_100US,	 last_sched_before      11560ms,	 tot_sched_cnt              5574805,	 last_exec_before      11560ms,	 tot_exec_cnt              5578795
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.400640] ath11k c000000.wifi: ce_time_dur_200US,	 last_sched_before      98660ms,	 tot_sched_cnt                 4014,	 last_exec_before     601240ms,	 tot_exec_cnt                  326
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.417783] ath11k c000000.wifi: ce_time_dur_300US,	 last_sched_before     238350ms,	 tot_sched_cnt                  279,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.434416] ath11k c000000.wifi: ce_time_dur_400US,	 last_sched_before   29469180ms,	 tot_sched_cnt                   16,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.451252] ath11k c000000.wifi: ce_time_dur_500US,	 last_sched_before   28865030ms,	 tot_sched_cnt                    6,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.468092] ath11k c000000.wifi: CE_id 3 pipe_num 3 7760ms before, sched_delay_gt_500US 1, exec_delay_gt_500US 0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.484920] ath11k c000000.wifi: ce_time_dur_100US,	 last_sched_before       7770ms,	 tot_sched_cnt               391737,	 last_exec_before       7770ms,	 tot_exec_cnt               391986
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.495409] ath11k c000000.wifi: ce_time_dur_200US,	 last_sched_before     418830ms,	 tot_sched_cnt                  185,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.512012] ath11k c000000.wifi: ce_time_dur_300US,	 last_sched_before    2105010ms,	 tot_sched_cnt                   63,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.528857] ath11k c000000.wifi: ce_time_dur_400US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.545696] ath11k c000000.wifi: ce_time_dur_500US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.562537] ath11k c000000.wifi: CE_id 5 pipe_num 5 244797560ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.579367] ath11k c000000.wifi: ce_time_dur_100US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.589962] ath11k c000000.wifi: ce_time_dur_200US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.607057] ath11k c000000.wifi: ce_time_dur_300US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.623736] ath11k c000000.wifi: ce_time_dur_400US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.640573] ath11k c000000.wifi: ce_time_dur_500US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.657459] ath11k c000000.wifi: CE_id 7 pipe_num 7 197988410ms before, sched_delay_gt_500US 1, exec_delay_gt_500US 0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.674264] ath11k c000000.wifi: ce_time_dur_100US,	 last_sched_before  197988420ms,	 tot_sched_cnt                 1513,	 last_exec_before  197988420ms,	 tot_exec_cnt                 1515
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.684900] ath11k c000000.wifi: ce_time_dur_200US,	 last_sched_before  198084340ms,	 tot_sched_cnt                    1,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.701798] ath11k c000000.wifi: ce_time_dur_300US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.718661] ath11k c000000.wifi: ce_time_dur_400US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.735480] ath11k c000000.wifi: ce_time_dur_500US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.752291] ath11k c000000.wifi: CE_id 9 pipe_num 9 244797750ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.769123] ath11k c000000.wifi: ce_time_dur_100US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.779721] ath11k c000000.wifi: ce_time_dur_200US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.796655] ath11k c000000.wifi: ce_time_dur_300US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.813489] ath11k c000000.wifi: ce_time_dur_400US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.830336] ath11k c000000.wifi: ce_time_dur_500US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.847173] ath11k c000000.wifi: CE_id 10 pipe_num 10 244797850ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.863999] ath11k c000000.wifi: ce_time_dur_100US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.874944] ath11k c000000.wifi: ce_time_dur_200US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.891714] ath11k c000000.wifi: ce_time_dur_300US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.908546] ath11k c000000.wifi: ce_time_dur_400US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.925394] ath11k c000000.wifi: ce_time_dur_500US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.942220] ath11k c000000.wifi: CE_id 11 pipe_num 11 244797940ms before, sched_delay_gt_500US 0, exec_delay_gt_500US 0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.959057] ath11k c000000.wifi: ce_time_dur_100US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.970005] ath11k c000000.wifi: ce_time_dur_200US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245095.986756] ath11k c000000.wifi: ce_time_dur_300US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245096.003590] ath11k c000000.wifi: ce_time_dur_400US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.info kernel: [245096.020435] ath11k c000000.wifi: ce_time_dur_500US,	 last_sched_before          0ms,	 tot_sched_cnt                    0,	 last_exec_before          0ms,	 tot_exec_cnt                    0
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.037268] ath11k c000000.wifi:
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.037268] Last interrupt received for each group:
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.054100] ath11k c000000.wifi: group_id 0 12530ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.062247] ath11k c000000.wifi: group_id 1 29130ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.067807] ath11k c000000.wifi: group_id 2 12540ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.073348] ath11k c000000.wifi: group_id 3 27620ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.078917] ath11k c000000.wifi: group_id 4 12200ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.084460] ath11k c000000.wifi: group_id 5 34940ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.090028] ath11k c000000.wifi: group_id 6 244798090ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.095587] ath11k c000000.wifi: group_id 7 12280ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.101473] ath11k c000000.wifi: group_id 8 12610ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.107041] ath11k c000000.wifi: group_id 9 13940ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.112585] ath11k c000000.wifi: group_id 10 12290ms before
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.118157] ath11k c000000.wifi: dst srng id 0 tp 32208, cur hp 32208, cached hp 32208 last hp 32208 napi processed before 12300ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.124056] ath11k c000000.wifi: dst srng id 1 tp 13584, cur hp 13584, cached hp 13584 last hp 13584 napi processed before 12630ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.135620] ath11k c000000.wifi: dst srng id 2 tp 16912, cur hp 16912, cached hp 16912 last hp 16912 napi processed before 13970ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.147419] ath11k c000000.wifi: dst srng id 3 tp 29504, cur hp 29504, cached hp 29504 last hp 29504 napi processed before 12330ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.159224] ath11k c000000.wifi: dst srng id 4 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 12640ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.171037] ath11k c000000.wifi: src srng id 5 hp 0, reap_hp 248, cur tp 0, cached tp 0 last tp 0 napi processed before 244798170ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.181448] ath11k c000000.wifi: src srng id 8 hp 2290, reap_hp 2290, cur tp 2290, cached tp 2230 last tp 2230 napi processed before 27730ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.193599] ath11k c000000.wifi: dst srng id 9 tp 23842, cur hp 23842, cached hp 23842 last hp 23842 napi processed before 27740ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.206192] ath11k c000000.wifi: src srng id 16 hp 3232, reap_hp 3232, cur tp 3232, cached tp 3224 last tp 3224 napi processed before 930ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.217825] ath11k c000000.wifi: src srng id 17 hp 3792, reap_hp 3792, cur tp 3792, cached tp 3784 last tp 3784 napi processed before 940ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.230667] ath11k c000000.wifi: src srng id 18 hp 4072, reap_hp 4072, cur tp 4072, cached tp 4064 last tp 4064 napi processed before 970ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.243264] ath11k c000000.wifi: src srng id 24 hp 200, reap_hp 200, cur tp 200, cached tp 192 last tp 192 napi processed before 220ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.255843] ath11k c000000.wifi: dst srng id 25 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 244798260ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.267733] ath11k c000000.wifi: src srng id 32 hp 16, reap_hp 12, cur tp 16, cached tp 16 last tp 12 napi processed before 245075760ms
Sun Dec 10 19:16:28 2023 kern.err kernel: [245096.278846] ath11k c000000.wifi: src srng id 35 hp 60, reap_hp 24, cur tp 28, cached tp 28 last tp 28 napi processed before 2570ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.291081] ath11k c000000.wifi: src srng id 36 hp 128, reap_hp 124, cur tp 128, cached tp 128 last tp 124 napi processed before 197989040ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.302629] ath11k c000000.wifi: src srng id 39 hp 20, reap_hp 16, cur tp 20, cached tp 20 last tp 16 napi processed before 197989050ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.315479] ath11k c000000.wifi: src srng id 41 hp 0, reap_hp 124, cur tp 0, cached tp 0 last tp 0 napi processed before 244798320ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.327804] ath11k c000000.wifi: src srng id 57 hp 860, reap_hp 860, cur tp 864, cached tp 864 last tp 864 napi processed before 12450ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.339694] ath11k c000000.wifi: src srng id 58 hp 788, reap_hp 788, cur tp 792, cached tp 792 last tp 792 napi processed before 12510ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.352023] ath11k c000000.wifi: src srng id 61 hp 1020, reap_hp 1020, cur tp 0, cached tp 0 last tp 0 napi processed before 245075850ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.364346] ath11k c000000.wifi: src srng id 66 hp 1020, reap_hp 1020, cur tp 0, cached tp 0 last tp 0 napi processed before 245075850ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.376676] ath11k c000000.wifi: dst srng id 81 tp 1728, cur hp 1728, cached hp 1728 last hp 1728 napi processed before 12500ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.388997] ath11k c000000.wifi: dst srng id 82 tp 1584, cur hp 1584, cached hp 1584 last hp 1584 napi processed before 12560ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.400633] ath11k c000000.wifi: dst srng id 85 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 244798400ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.412175] ath11k c000000.wifi: dst srng id 90 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 244798410ms
*** Cut some of these for max post size ***
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.543078] ath11k c000000.wifi: dst srng id 134 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 244798540ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.553754] ath11k c000000.wifi: src srng id 135 hp 8190, reap_hp 8190, cur tp 0, cached tp 0 last tp 0 napi processed before 245075920ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.564701] ath11k c000000.wifi: src srng id 143 hp 8190, reap_hp 8190, cur tp 0, cached tp 0 last tp 0 napi processed before 29630ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.577021] ath11k c000000.wifi: src srng id 145 hp 254, reap_hp 254, cur tp 0, cached tp 0 last tp 0 napi processed before 245075940ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.589086] ath11k c000000.wifi: src srng id 147 hp 530, reap_hp 530, cur tp 532, cached tp 532 last tp 532 napi processed before 35450ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.601500] ath11k c000000.wifi: dst srng id 148 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 29670ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.613900] ath11k c000000.wifi: dst srng id 149 tp 0, cur hp 0, cached hp 0 last hp 0 napi processed before 244798610ms
Sun Dec 10 19:16:29 2023 kern.err kernel: [245096.624426] ath11k c000000.wifi: src srng id 150 hp 8190, reap_hp 8190, cur tp 0, cached tp 0 last tp 0 napi processed before 245075980ms
Sun Dec 10 19:16:30 2023 kern.warn kernel: [245096.635384] ------------[ cut here ]------------
Please try this workaround:
Ok, thanks. I have installed the WLAN.HK.2.5.0.1 firmware. I will come back with an update.
@hansome I can confirm now that Slate AX with the wireless driver WLAN.HK.2.5.0.1-01208-QCAHKSWPL_SILICONZ-1.tar is stable. I don’t have any issues now with random restarts!
Why is this driver not included in the current firmware? Any idea when it will be?
Thank you very much for the feedback. The current wireless driver WLAN.HK.2.6 is for solving the repeater crash when connecting an HT160 AP. We’re considering upgrading the kernel to solve the issue radically.
