GL-AXT1800 does not apply 149,153,157,161,165 Wi-FI channels
In the 5GHz WiFi channel selection settings, it is not possible to select channels 149,153,157,161,165.
5g0
After applying the settings, Wi-Fi on these channels is not available.
In Luci after the commit the window with the current channel is empty, and these channels are not presented in the drop list.
In the text config these channels are listed.
config wifi-device 'radio0'
        option type 'mac80211'
        option path 'platform/soc/c000000.wifi'
        option band '5g'
        option htmode 'HE80'
        option hwmode '11a'
        option cell_density '0'
        option txpower '23'
        option channels '36,40,44,48,149,153,157,161,165'
        option channel 'auto'
        option country 'GB'
I tried to change the country but it does not help. What could be the problem?
These channels does not work in the Europle
I understand that for these channels, 10mW is allowed. But the router’s wifi driver does not support these at all when you use EU region code.
