Hi, I just upgraded my GL-AXT1800 to fw 4.6.4 (release1, Compile Time 2024-09-05 00:22:50 (UTC+00:00)) and the wireless page stopped working. I found Wireless page crash (rpc err 500) after 4.6.4 update in the forum with someone reporting the same issue so I ran the command specified in one answer there:
uci set wireless.default_radio0.ifname='wlan1'
uci set wireless.default_radio1.ifname='wlan0'
uci set wireless.guest5g.ifname='wlan1-1'
uci set wireless.guest2g.ifname='wlan0-1'
uci commit wireless
reboot
And that made the wireless page show the 5GHz tab (but only that). I can see the 2g configuration using uci show and I can even change the ssid using uci set wireless.default_radio1.ssid='foobar' followed by the commit and reboot so it seems to be working fine but I still can't see the 2.4GHz tab nor guest tabs in the web admin.
Btw, in the "Internet" page I can see the 5G and 2.4G icons enabled (both show their respective QR codes) but no matter which one I click, they both get me to the same 5G tab in the wireless page.
Btw, the advanced settings work fine and I can edit all wireless configurations there.
My wireless configuration (using uci show | grep ^wireless) is:
wireless.radio0=wifi-device
wireless.radio0.type='mac80211'
wireless.radio0.path='platform/soc/c000000.wifi'
wireless.radio0.band='5g'
wireless.radio0.htmode='HE80'
wireless.radio0.country='DE'
wireless.radio0.disabled='0'
wireless.radio0.channel='auto'
wireless.radio0.legacy_rates='0'
wireless.radio0.channels='36,40,44,48'
wireless.radio0.hwmode='11a'
wireless.radio0.txpower='21'
wireless.radio0.random_bssid='1'
wireless.default_radio0=wifi-iface
wireless.default_radio0.device='radio0'
wireless.default_radio0.network='lan'
wireless.default_radio0.mode='ap'
wireless.default_radio0.encryption='psk2'
wireless.default_radio0.wds='1'
wireless.default_radio0.isolate='0'
wireless.default_radio0.hidden='0'
wireless.default_radio0.key='REDACTED'
wireless.default_radio0.disabled='0'
wireless.default_radio0.ssid='REDACTED'
wireless.default_radio0.macaddr='0E:52:68:REDACTED'
wireless.radio1=wifi-device
wireless.radio1.type='mac80211'
wireless.radio1.path='platform/soc/c000000.wifi+1'
wireless.radio1.band='2g'
wireless.radio1.country='DE'
wireless.radio1.disabled='0'
wireless.radio1.htmode='HE40'
wireless.radio1.legacy_rates='0'
wireless.radio1.hwmode='11g'
wireless.radio1.random_bssid='1'
wireless.radio1.txpower='21'
wireless.radio1.channel='auto'
wireless.default_radio1=wifi-iface
wireless.default_radio1.device='radio1'
wireless.default_radio1.network='lan'
wireless.default_radio1.mode='ap'
wireless.default_radio1.encryption='psk2'
wireless.default_radio1.wds='1'
wireless.default_radio1.isolate='0'
wireless.default_radio1.hidden='0'
wireless.default_radio1.key='REDACTED'
wireless.default_radio1.disabled='0'
wireless.default_radio1.ssid='REDACTED'
wireless.default_radio1.macaddr='6A:E7:E5:REDACTED'
wireless.guest5g=wifi-iface
wireless.guest5g.device='radio0'
wireless.guest5g.network='guest'
wireless.guest5g.mode='ap'
wireless.guest5g.encryption='psk2'
wireless.guest5g.ssid='GL-AXT1800-06d-5G-Guest'
wireless.guest5g.guest='1'
wireless.guest5g.disabled='1'
wireless.guest5g.wds='1'
wireless.guest5g.isolate='1'
wireless.guest5g.key='REDACTED'
wireless.guest5g.macaddr='EE:98:B5:REDACTED'
wireless.guest2g=wifi-iface
wireless.guest2g.device='radio1'
wireless.guest2g.network='guest'
wireless.guest2g.mode='ap'
wireless.guest2g.encryption='psk2'
wireless.guest2g.ssid='GL-AXT1800-06d-Guest'
wireless.guest2g.guest='1'
wireless.guest2g.disabled='1'
wireless.guest2g.wds='1'
wireless.guest2g.isolate='1'
wireless.guest2g.key='REDACTED'
wireless.guest2g.macaddr='0E:DD:B3:REDACTED'
