Just a moment, let me check
I think I need a log
logread.tar (158.5 KB)
Please check it, thanks
This log is all about relays
There are no modem logs
@ywp where i must get it? because now i try to export logs from standart menu
When something goes wrong, download the log as soon as possible
Too long time the error log will be overwritten
But I have constant problems, I can provide you with a photo at any time, there is always no connection. Any sim card, from any operator, at any moment of time, says NO INTERNET to me on the display.
Can I check it remotely?
Technical Support via GoodCloud.tar (192 KB)
Yes, i'm write you to private message
2 posts were split to a new topic: GL-M2 board with RM520 with Visible and AXT1800
What does it display on the web admin panel?
Do you have normal Internet now or does not have Internet?
Hello, for this time all is ok. But give me more time, i'm again travel all day and will send you more photos of time when internet will be shutdown.
Just i need it for work, and not give this device with myself when i need guaranteed stable internet
OK. Pls let me know.
Hello, i invited you to pm, please check. Thanks
I have returned the GL-M2 product, so I'm not sure how things are going.
