4.5 releas2 had “invalid date” for compile time. it would not take the 4.5.16 update with keep settings. which I assumed was the reason. performed local file update. is this the current expected result?
I am not sure if this is “expected”, but I observed the same, compile time is invalid date.
I see this as well on my Slate AX. Something between 4.5.0 and 4.5.16 change has cause this. I also see this on my Beryl AX in 4.5.x.
4.6.0 release does not reproduce this issue.
