GL-AXT1800 kernel panic
Was using my devices when suddenly the Internet cut out. Checked logs and it seems like the router suffered a kernel panic. Here are the logs:
Oops#1 Part1
<4>[1199491.003340] CPU: 1 PID: 121 Comm: kworker/1:1 Not tainted 4.4.60 #0
<4>[1199491.003695] Hardware name: Generic DT based system
<4>[1199491.010126] Workqueue: events rproc_crash_handler_work
<4>[1199491.020091] task: 9dec5e80 ti: 9d922000 task.ti: 9d922000
<4>[1199491.020405] PC is at ath11k_core_ssr_notifier_cb+0xa4/0xb4 [ath11k]
<4>[1199491.025774] LR is at ath11k_hal_dump_srng_stats+0x248/0x2c0 [ath11k]
<4>[1199491.032343] pc : [<7f79d064>]    lr : [<7f79f764>]    psr: 60000013
<4>[1199491.032343] sp : 9d923e28  ip : 00000000  fp : 9d816428
<4>[1199491.038775] r10: 8083a520  r9 : 9d816664  r8 : 00000000
<4>[1199491.050482] r7 : 8075fee0  r6 : 9e5af610  r5 : 8075fee0  r4 : 9ad1092c
<4>[1199491.056041] r3 : 00000000  r2 : dc8ba63c  r1 : 00000000  r0 : 0000007e
<4>[1199491.062812] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
<4>[1199491.069497] Control: 10c0383d  Table: 5794806a  DAC: 00000055
<0>[1199491.076871] Process kworker/1:1 (pid: 121, stack limit = 0x9d922210)
<0>[1199491.082603] Stack: (0x9d923e28 to 0x9d924000)
<0>[1199491.089198] 3e20:                   00000002 9ad1192c 00000000 fffffffd 00000000 80044da0
<0>[1199491.093632] 3e40: 8087d520 00000000 8075fee0 ffffffff 9d816428 80045094 00000000 9d923e6c
<0>[1199491.101966] 3e60: 00000000 9d816778 9d816604 00000001 9d816400 800450c8 00000000 803572ec
<0>[1199491.110299] 3e80: 9d81662c 8044c40c 9d81662c 9d816664 9d816400 9d81662c 9d8165c0 8044df58
<0>[1199491.118633] 3ea0: 00000001 80357180 8073f73c 8075efec 9d8074c0 00000000 31e2b3b9 9d81662c
<0>[1199491.126967] 3ec0: 9d816664 00000003 9d81662c 9d8165c0 9d816664 8083a520 9eb4cb40 8044e290
<0>[1199491.135299] 3ee0: 8044e164 9d81662c 9df42800 9eb4cb40 9eb50000 00000000 00000000 8083a520
<0>[1199491.143632] 3f00: 9eb4cb40 8003ed30 9eb4cb40 9eb4cb40 00000008 9df42800 9df42818 9eb4cb40
<0>[1199491.151965] 3f20: 00000008 9eb4cb54 9d922000 8083a520 9eb4cb40 8003f1b0 80836100 9df42800
<0>[1199491.160298] 3f40: 8003eec8 00000000 9df43380 9df42800 8003eec8 00000000 00000000 00000000
<0>[1199491.168632] 3f60: 00000000 8004428c 00000000 00000000 00000000 9df42800 00000000 00000000
<0>[1199491.176966] 3f80: 9d923f80 9d923f80 00000000 00000000 9d923f90 9d923f90 9d923fac 9df43380
<0>[1199491.185298] 3fa0: 8004419c 00000000 00000000 80009c28 00000000 00000000 00000000 00000000
<0>[1199491.193632] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[1199491.194782] ath11k c000000.wifi: bss channel survey timed out
<0>[1199491.210295] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
<4>[1199491.216326] [<7f79d064>] (ath11k_core_ssr_notifier_cb [ath11k]) from [<80044da0>] (notifier_call_chain+0x2c/0x70)
<4>[1199491.224544] [<80044da0>] (notifier_call_chain) from [<80045094>] (__blocking_notifier_call_chain+0x48/0x64)
<4>[1199491.234956] [<80045094>] (__blocking_notifier_call_chain) from [<800450c8>] (blocking_notifier_call_chain+0x18/0x20)
<4>[1199491.245030] [<800450c8>] (blocking_notifier_call_chain) from [<8044c40c>] (rproc_stop+0x2c/0xc4)
<4>[1199491.255616] [<8044c40c>] (rproc_stop) from [<8044df58>] (rproc_trigger_recovery+0x4c/0x258)
<4>[1199491.264556] [<8044df58>] (rproc_trigger_recovery) from [<8044e290>] (rproc_crash_handler_work+0x12c/0x1bc)
<4>[1199491.273153] [<8044e290>] (rproc_crash_handler_work) from [<8003ed30>] (process_one_work+0x220/0x3b8)
<4>[1199491.283046] [<8003ed30>] (process_one_work) from [<8003f1b0>] (worker_thread+0x2e8/0x4d0)
<4>[1199491.292157] [<8003f1b0>] (worker_thread) from [<8004428c>] (kthread+0xf0/0xf8)
<4>[1199491.300404] [<8004428c>] (kthread) from [<80009c28>] (ret_from_fork+0x14/0x2c)
<0>[1199491.308042] Code: eb2b2ceb e3500000 0affffe9 ea000000 (e7f001f2)
<4>[1199491.315421] ---[ end trace 174aa87513e4df8f ]---
Panic#2 Part1
 x_tables nf_reject_ipv6 bonding ifb ip6_udp_tunnel udp_tunnel qca_nss_drv qca_nss_dp udp_diag tcp_diag raw_diag inet_diag tun qca_ssdk vfat fat ntfs nls_utf8 nls_iso8859_1 nls_cp437 mtdoops uas usb_storage gl_fan_driver xhci_plat_hcd xhci_pci xhci_hcd dwc3 dwc3_qcom dbm uhci_hcd ohci_platform ohci_hcd phy_msm_ssusb_qmp phy_msm_qusb ehci_platform sd_mod scsi_mod kmwan ehci_hcd gpio_button_hotplug gl_sdk4_tertf gl_sdk4_black_white_list usbcore nls_base usb_common mii gl_sdk4_hw_info
<0>[1199491.327753] Kernel panic - not syncing: Fatal exception
<2>[1199491.327775] CPU3: stopping
<4>[1199491.332118] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D         4.4.60 #0
<4>[1199491.335071] Hardware name: Generic DT based system
<4>[1199491.342110] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[1199491.347319] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[1199491.355041] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[1199491.362593] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[1199491.369972] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[1199491.377868] Exception stack(0x9e48ff88 to 0x9e48ffd0)
<4>[1199491.385244] ff80:                   00000001 00000000 00000000 8000b400 9e48e000 808364a0
<4>[1199491.390458] ffa0: 806d2f48 00000000 00000000 8082f30c 9e48ffe0 808364a8 9e48ff80 9e48ffd8
<4>[1199491.398789] ffc0: 80019394 80019398 60000013 ffffffff
<4>[1199491.407120] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[1199491.412334] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[1199491.419975] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<2>[1199491.428561] CPU0: stopping
<4>[1199491.435586] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.4.60 #0
<4>[1199491.438543] Hardware name: Generic DT based system
<4>[1199491.445577] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[1199491.450789] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[1199491.458513] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[1199491.466065] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[1199491.473444] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[1199491.481339] Exception stack(0x80835f50 to 0x80835f98)
<4>[1199491.488714] 5f40:                                     00000001 00000000 00000000 8000b400
<4>[1199491.493930] 5f60: 80834000 808364a0 806d2f48 00000000 00000000 8082f30c 80835fa8 808364a8
<4>[1199491.502262] 5f80: 80835f48 80835fa0 80019394 80019398 60000013 ffffffff
<4>[1199491.510595] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[1199491.517542] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[1199491.525011] [<80063664>] (cpu_startup_entry) from [<807f7d28>] (start_kernel+0x430/0x43c)
<2>[1199491.533597] CPU2: stopping
<4>[1199491.541663] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D         4.4.60 #0
<4>[1199491.544793] Hardware name: Generic DT based system
<4>[1199491.551826] [<8001f784>] (unwind_backtrace) from [<8001bad4>] (show_stack+0x10/0x14)
<4>[1199491.557038] [<8001bad4>] (show_stack) from [<80260c10>] (dump_stack+0x8c/0xa0)
<4>[1199491.564763] [<80260c10>] (dump_stack) from [<8001e6e0>] (handle_IPI+0x104/0x190)
<4>[1199491.572315] [<8001e6e0>] (handle_IPI) from [<800093bc>] (gic_handle_irq+0x80/0x94)
<4>[1199491.579694] [<800093bc>] (gic_handle_irq) from [<8000a4c0>] (__irq_svc+0x40/0x74)
<4>[1199491.587588] Exception stack(0x9e48df88 to 0x9e48dfd0)
<4>[1199491.594966] df80:                   00000001 00000000 00000000 8000b400 9e48c000 808364a0
<4>[1199491.600180] dfa0: 806d2f48 00000000 00000000 8082f30c 9e48dfe0 808364a8 9e48df80 9e48dfd8
<4>[1199491.608512] dfc0: 80019394 80019398 60000013 ffffffff
<4>[1199491.616841] [<8000a4c0>] (__irq_svc) from [<80019398>] (arch_cpu_idle+0x34/0x50)
<4>[1199491.622055] [<80019398>] (arch_cpu_idle) from [<80063664>] (cpu_startup_entry+0x154/0x228)
<4>[1199491.629694] [<80063664>] (cpu_startup_entry) from [<4100946c>] (0x4100946c)
<0>[1199491.638289] The reading for sensor 4 is 0x002042c4
<0>[1199491.645359] Couldn't get reading for sensor 5
<0>[1199491.650346] The reading for sensor 7 is 0x002072be
<0>[1199491.654601] The reading for sensor 8 is 0x002082b4
<0>[1199491.659855] Couldn't get reading for sensor 13
<0>[1199491.664756] The reading for sensor 14 is 0x0020e2ba
<0>[1199491.669404] Couldn't get reading for sensor 15
