Hello support team.
In order to use the GL-AXT 1800, I plugged a Huawei E3372h-320 LTE into the USB port.
The stick is connected as eth3, but no website can be opened.
The stick works in a notebook.
What can be the reason?
Thanks
Jens
Hello support team.
Thanks
Jens
Pls change lan IP of AXT1800 to 192.168.10.1 or others.
Huawei also use 192.168.8.1 so it conflicts.
Hi,You can refer to this topic.Slate AX and Huawai E3372h - tethering mode not working - #8 by pinus
… thank you. I will it change and test it.
Jens
Hi, did it work for you with the amended IP Address?
yes - it works perfect.
Thank you very much.
Jens
