Hi all,
I have a GL-AXT1800 and my goal is to run a guest WLAN (Open) which is routed
via a Wireguard VPN and a “normal” WLAN (WPA3) which goes directly to the Internet.
This also works configured via the WebUI, but the DNS server of the WireGuard VPN
is also used for the “normal” WLAN. This means that hostnames that are only available
on the LAN can no longer be resolved.
So the question is how can I specify one DNS server per VLAN/SSID?
Thanks for your help!
//edit: Fixed it myself, but in my opinion this should also be possible via the GUI, or it should work like this by default.
