I have an OpenVPN client configuration file that I was able to import. when i try to start it via the webgui nothing happens (unfortunately i didn’t find any logs file otherwise i would post something). If I start openvpn via the terminal with specification of the config file
openvpn xxx_client2.ovpn
, the vpn starts. So basically the configuration works. how can i get it to run
I installed the beta firmware.
I only have the backup configuration in advanced settings.
when i press the start button the vpn is not established, where can i find the log files so i can post them?
I did it again over your webui with the beta firmware. now it works to build the openvpn tunnel. I can reach everything in the company, but I can’t reach it on the internet (ping 8.8.8.8 or ping heise.de) doesn’t work. I also tried to change the setting with policy bvased routing so that everything that is internet is not done via the vpn
I solved it, after resetting and installing the 4.1 firmware it worked. I still had to use policy based (had first tried it with “Not Use VPN” 192.168.8.1 and 0.0.0.0/0) that didn’t want to.
