GL-AXT1800 reboot loop
Greetings!
So, I have a GL-AXT1800 router, which is absolutely perfect for my use cases. But one day, it starts endless reboots. The router is starting, works 3-4 minutes, and… reboots. The main problem here: I didn’t make any changes in settings for a while. The router just stops working today. Could you please help me to figuring out what is happened, and how can I fix it?
Here is a crash.log
logread.zip (33.6 KB)
You have various crash.
What is your firmware version?
Do you use repeater?
In some firmware, when connecting to a certain type of wifi network, it crashes. Not sure if this is your issue. But here is how to troubleshoot
  1. Use one good power adapter
  2. Reset the router and upgrade the firmware
  3. Set up again.
