GL-AXT1800 (Slate AX) dropping connection every 30 mins
v4.6.2
Over the last few weeks I have been having connection drops through wifi and hard wired connections roughly every 30 minutes.
kern.log
[ 25.946256] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 26.348592] IPv6: ADDRCONF(NETDEV_UP): wgserver: link is not ready
[ 26.640707] device wlan0 entered promiscuous mode
[ 26.640814] br-lan: port 3(wlan0) entered forwarding state
[ 26.644471] br-lan: port 3(wlan0) entered forwarding state
[ 26.782425] device wlan1 entered promiscuous mode
[ 26.782540] br-lan: port 4(wlan1) entered forwarding state
[ 26.786206] br-lan: port 4(wlan1) entered forwarding state
[ 26.904506] br-lan: port 3(wlan0) entered disabled state
[ 26.904770] br-lan: port 4(wlan1) entered disabled state
[ 27.415202] tertf: br-lan registered, add it
[ 30.470429] ath11k c000000.wifi: bss color param 0x81000000 set on vdev 1
[ 30.470517] br-lan: port 4(wlan1) entered forwarding state
[ 30.476253] br-lan: port 4(wlan1) entered forwarding state
[ 33.924439] br-lan: port 2(eth2) entered forwarding state
[ 38.100583] [add_dev_config 287]add node success. iface:wan, dev:eth0, ifindex:2
[ 38.484443] br-lan: port 4(wlan1) entered forwarding state
[ 39.361963] ath11k c000000.wifi: bss color param 0x81000000 set on vdev 0
[ 39.362064] br-lan: port 3(wlan0) entered forwarding state
[ 39.367809] br-lan: port 3(wlan0) entered forwarding state
[ 47.384423] br-lan: port 3(wlan0) entered forwarding state
[11656.707776] conntrack: generic helper won't handle protocol 47. Please consider loading the specific helper module.
system.log
Thu Jul 25 08:42:12 2024 user.notice AdGuardHome[6418]: 2024/07/25 12:42:12.784919 [error] dnsproxy: 9.9.9.9:53: response received over udp: "exchanging with 9.9.9.9:53 over udp: read udp 76.128.215.117:47416->9.9.9.9:53: i/o timeout"
Thu Jul 25 08:42:12 2024 user.notice AdGuardHome[6418]: 2024/07/25 12:42:12.785066 [error] dnsproxy: upstream 9.9.9.9:53 failed to exchange ;fi.telephony.goog. IN A in 20.002125994s: exchanging with 9.9.9.9:53 over udp: read udp 76.128.215.117:47416->9.9.9.9:53: i/o timeout
Thu Jul 25 08:42:12 2024 user.notice AdGuardHome[6418]: 2024/07/25 12:42:12.904537 [error] dnsproxy: 8.8.8.8:53: response received over udp: "exchanging with 8.8.8.8:53 over udp: read udp 76.128.215.117:33080->8.8.8.8:53: i/o timeout"
Thu Jul 25 08:42:12 2024 user.notice AdGuardHome[6418]: 2024/07/25 12:42:12.904694 [error] dnsproxy: upstream 8.8.8.8:53 failed to exchange ;ssl.gstatic.com. IN A in 20.001029329s: exchanging with 8.8.8.8:53 over udp: read udp 76.128.215.117:33080->8.8.8.8:53: i/o timeout
Thu Jul 25 08:42:12 2024 user.notice AdGuardHome[6418]: 2024/07/25 12:42:12.904535 [error] dnsproxy: 8.8.8.8:53: response received over udp: "exchanging with 8.8.8.8:53 over udp: read udp 76.128.215.117:56213->8.8.8.8:53: i/o timeout"
Thu Jul 25 08:42:12 2024 user.notice AdGuardHome[6418]: 2024/07/25 12:42:12.904808 [error] dnsproxy: upstream 8.8.8.8:53 failed to exchange ;ssl.gstatic.com. IN HTTPS in 20.000756912s: exchanging with 8.8.8.8:53 over udp: read udp 76.128.215.117:56213->8.8.8.8:53: i/o timeout
There is nothing in the crash log is there anything else I can monitor or should be looking for. This is very frustrating when trying to demo something on zoom and it crashes multiple times.
the syslog which you post could not find some effective information.
could you please export the logread.tar file when you met the wireless and wired cut off, and upload it here?
Had the same issue with the 4.6 firmware, after i downgraded back to 4.5 everything is stable and works fine. I tried all the settings and is just a waste of time, after going back to 4.5 all is stable
