GL-AXT1800 Slate AX, FW 4.2.1 release2 has release note for MT3000
Model: GL-AXT1800 Slate AX
Version: 4.2.1 release2
Date Compiled: 2023-03-25 11:48:19 (UTC+07:00)
SHA256: 09346cd742eb846c6ed9de2d6c3825649d9a904ea47673dc9bd7f7ffa9776a5c
Release Notes:
V4.2.1
Bug Fixes
  • Fixed a problem where the WiFi configuration page showed unavailable channel options.
  • Fixed a problem where NordVPN could not resolve DNS after keeping settings upgrade.
  • Fixed a problem where GL-MT3000 failed to recognize USB3.0 modem.
  • Fixed a problem where the IPV6 rate limiting does not take effect.
  • Fixed a problem where GL-MT3000 failed to repeat to iPhone 13 and TP-LINK ACR700.
  • Fixed a memory leak problem in GL-MT3000 when using QCM protocol.
  • Fixed a probabilistic issue where GL-MT3000 could not apply OpenVPN username and password.
Optimizations
  • Disabled nginx access logs.
  • Optimized the MWAN3 online detection threshold.
  • Optimized the synchronization of configuration files in abnormal situations.
  • Optimized the repeater scan time of GL-MT3000.
Software Upgrade
  • Upgraded AdguardHome to V0.107.26.
There are actually numerous references to the MT-3000. So the obvious is to which router does this release apply? Slate or Beryl?
If no model is specified, then that change applies to all models.
