Device : Slate AX
Firmware : 4.4.6 (problem already existed before the update from version 4.2.1)
Network mode : Repeater (from a Starlink Wifi network)
Problem description :
Several devices are connected to my Slate AX router via LAN cable and some devices via Wifi (both 2.4 GHz and 5 GHz). The LAN clients work without any problems, but with all Wifi clients the problem occurs that after some time that the Wifi connection remains unused, no more data is transferred when the client is used again. The Wifi connection to this device is then still available, but there is no longer any data transfer between this specific client and the Slate. If you then deactivate and reactivate the Wifi connection on the client, everything works normally again. The problem occurs with all Wi-Fi devices (smartphone, tablet).
Of course, it is annoying that you have to re-establish the Wi-Fi connection every time after 5-10 minutes of inactivity. The problem occurs at both 2.4 GHz and 5 GHz.
admon
January 6, 2024, 11:40am
2
So ping
does not work either?
Please upload the logs of the router as well.
I’ll test ping and respond to your question.
Here the logs:
Sat Jan 6 10:50:07 2024 daemon.notice netifd: wwan (16284): udhcpc: sending renew to 192.168.1.1
Sat Jan 6 10:50:07 2024 daemon.notice netifd: wwan (16284): udhcpc: lease of 192.168.1.21 obtained, lease time 3600
Sat Jan 6 10:51:45 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 10:53:45 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 10:55:45 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 10:55:55 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.120 b8:27:eb:57:65:04
Sat Jan 6 10:55:55 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.120 b8:27:eb:57:65:04 pi3
Sat Jan 6 10:57:46 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 10:59:46 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:01:46 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:03:46 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:05:46 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:06:32 2024 daemon.notice wpa_supplicant[2863]: wlan-sta0: WPA: Group rekeying completed with ba:d2:23:3a:87:b5 [GTK=CCMP]
Sat Jan 6 11:06:32 2024 daemon.info repeater: (/usr/sbin/repeater:470) <3>WPA: Group rekeying completed with ba:d2:23:3a:87:b5 [GTK=CCMP]
Sat Jan 6 11:07:47 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:09:47 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:11:47 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:13:47 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:15:47 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:17:47 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:19:47 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:20:07 2024 daemon.notice netifd: wwan (16284): udhcpc: sending renew to 192.168.1.1
Sat Jan 6 11:20:07 2024 daemon.notice netifd: wwan (16284): udhcpc: lease of 192.168.1.21 obtained, lease time 3600
Sat Jan 6 11:21:48 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:23:48 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:24:11 2024 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED dc:90:88:90:9b:7a 0 0
Sat Jan 6 11:24:11 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a IEEE 802.11: disassociated due to inactivity
Sat Jan 6 11:24:12 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sat Jan 6 11:25:49 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:27:49 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:29:49 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:31:27 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.222 a8:e7:7d:2c:bf:8e
Sat Jan 6 11:31:27 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.222 a8:e7:7d:2c:bf:8e Kostal
Sat Jan 6 11:31:49 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:33:50 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:35:50 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:37:50 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:39:50 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:40:45 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a IEEE 802.11: authenticated
Sat Jan 6 11:40:45 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a IEEE 802.11: associated (aid 1)
Sat Jan 6 11:40:45 2024 daemon.notice hostapd: wlan0-1: AP-STA-CONNECTED dc:90:88:90:9b:7a 0 0
Sat Jan 6 11:40:45 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a RADIUS: starting accounting session 0AFA860AD4093134
Sat Jan 6 11:40:45 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a WPA: pairwise key handshake completed (RSN)
Sat Jan 6 11:40:46 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.69 dc:90:88:90:9b:7a
Sat Jan 6 11:40:46 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.69 dc:90:88:90:9b:7a HUAWEI_Mate_20_lite-d07e6
Sat Jan 6 11:41:50 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:43:50 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:45:50 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:47:50 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:49:50 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:50:07 2024 daemon.notice netifd: wwan (16284): udhcpc: sending renew to 192.168.1.1
Sat Jan 6 11:50:07 2024 daemon.notice netifd: wwan (16284): udhcpc: lease of 192.168.1.21 obtained, lease time 3600
Sat Jan 6 11:51:51 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:53:51 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:55:51 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:57:52 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 11:58:21 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.188 00:1e:c0:bb:c6:ff
Sat Jan 6 11:58:21 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.188 00:1e:c0:bb:c6:ff
Sat Jan 6 11:59:52 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:00:12 2024 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED 74:60:fa:a3:ef:1c 0 0
Sat Jan 6 12:00:12 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c IEEE 802.11: disassociated
Sat Jan 6 12:00:13 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sat Jan 6 12:00:14 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c IEEE 802.11: authenticated
Sat Jan 6 12:00:14 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c IEEE 802.11: associated (aid 2)
Sat Jan 6 12:00:14 2024 daemon.notice hostapd: wlan0-1: AP-STA-CONNECTED 74:60:fa:a3:ef:1c 0 0
Sat Jan 6 12:00:14 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c RADIUS: starting accounting session 023FABAA696E3DD6
Sat Jan 6 12:00:14 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c WPA: pairwise key handshake completed (RSN)
Sat Jan 6 12:00:14 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.12 74:60:fa:a3:ef:1c
Sat Jan 6 12:00:14 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.12 74:60:fa:a3:ef:1c HUAWEI_MediaPad_M5_lite_1
Sat Jan 6 12:01:52 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:03:52 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:03:55 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a IEEE 802.11: disconnected due to excessive missing ACKs
Sat Jan 6 12:03:55 2024 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED dc:90:88:90:9b:7a 0 0
Sat Jan 6 12:04:17 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a IEEE 802.11: authenticated
Sat Jan 6 12:04:17 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a IEEE 802.11: associated (aid 1)
Sat Jan 6 12:04:17 2024 daemon.notice hostapd: wlan0-1: AP-STA-CONNECTED dc:90:88:90:9b:7a 0 0
Sat Jan 6 12:04:17 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a RADIUS: starting accounting session 0AFA860AD4093134
Sat Jan 6 12:04:17 2024 daemon.info hostapd: wlan0-1: STA dc:90:88:90:9b:7a WPA: pairwise key handshake completed (RSN)
Sat Jan 6 12:04:17 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.69 dc:90:88:90:9b:7a
Sat Jan 6 12:04:17 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.69 dc:90:88:90:9b:7a HUAWEI_Mate_20_lite-d07e6
Sat Jan 6 12:05:52 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:06:34 2024 daemon.notice wpa_supplicant[2863]: wlan-sta0: WPA: Group rekeying completed with ba:d2:23:3a:87:b5 [GTK=CCMP]
Sat Jan 6 12:06:34 2024 daemon.info repeater: (/usr/sbin/repeater:470) <3>WPA: Group rekeying completed with ba:d2:23:3a:87:b5 [GTK=CCMP]
Sat Jan 6 12:07:52 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:09:53 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:11:53 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:13:53 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:15:53 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:17:53 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:18:59 2024 daemon.info dnsmasq-dhcp[1350]: DHCPDISCOVER(br-lan) 192.168.8.100 a8:a1:59:57:78:3b
Sat Jan 6 12:18:59 2024 daemon.info dnsmasq-dhcp[1350]: DHCPOFFER(br-lan) 192.168.8.100 a8:a1:59:57:78:3b
Sat Jan 6 12:18:59 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.100 a8:a1:59:57:78:3b
Sat Jan 6 12:18:59 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.100 a8:a1:59:57:78:3b Linux-PC
Sat Jan 6 12:19:53 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:20:07 2024 daemon.notice netifd: wwan (16284): udhcpc: sending renew to 192.168.1.1
Sat Jan 6 12:20:07 2024 daemon.notice netifd: wwan (16284): udhcpc: lease of 192.168.1.21 obtained, lease time 3600
Sat Jan 6 12:20:19 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 IEEE 802.11: authenticated
Sat Jan 6 12:21:53 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:23:53 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:25:19 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sat Jan 6 12:25:54 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:27:02 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.127 10:5b:ad:1d:b2:7c
Sat Jan 6 12:27:02 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.127 10:5b:ad:1d:b2:7c BRW105BAD1DB27C
Sat Jan 6 12:27:54 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:29:54 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:30:02 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 IEEE 802.11: authenticated
Sat Jan 6 12:31:43 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 IEEE 802.11: authenticated
Sat Jan 6 12:31:52 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 IEEE 802.11: disassociated
Sat Jan 6 12:31:53 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sat Jan 6 12:31:54 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:33:54 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:35:55 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:36:27 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 IEEE 802.11: authenticated
Sat Jan 6 12:36:27 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 IEEE 802.11: associated (aid 3)
Sat Jan 6 12:36:27 2024 daemon.notice hostapd: wlan1: AP-STA-CONNECTED b8:27:eb:02:30:51 0 0
Sat Jan 6 12:36:27 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 RADIUS: starting accounting session 8C3CAA89233EB2FF
Sat Jan 6 12:36:27 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 WPA: pairwise key handshake completed (RSN)
Sat Jan 6 12:36:34 2024 daemon.info dnsmasq-dhcp[1350]: DHCPDISCOVER(br-lan) b8:27:eb:02:30:51
Sat Jan 6 12:36:34 2024 daemon.info dnsmasq-dhcp[1350]: DHCPOFFER(br-lan) 192.168.8.225 b8:27:eb:02:30:51
Sat Jan 6 12:36:36 2024 daemon.info dnsmasq-dhcp[1350]: DHCPDISCOVER(br-lan) b8:27:eb:02:30:51
Sat Jan 6 12:36:36 2024 daemon.info dnsmasq-dhcp[1350]: DHCPOFFER(br-lan) 192.168.8.225 b8:27:eb:02:30:51
Sat Jan 6 12:36:36 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.225 b8:27:eb:02:30:51
Sat Jan 6 12:36:36 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.225 b8:27:eb:02:30:51 pi3
Sat Jan 6 12:37:55 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:38:02 2024 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED 74:60:fa:a3:ef:1c 0 0
Sat Jan 6 12:38:02 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c IEEE 802.11: disassociated
Sat Jan 6 12:38:03 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sat Jan 6 12:38:05 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c IEEE 802.11: authenticated
Sat Jan 6 12:38:05 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c IEEE 802.11: associated (aid 2)
Sat Jan 6 12:38:05 2024 daemon.notice hostapd: wlan0-1: AP-STA-CONNECTED 74:60:fa:a3:ef:1c 0 0
Sat Jan 6 12:38:05 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c RADIUS: starting accounting session C91415D6C6EDF9FC
Sat Jan 6 12:38:05 2024 daemon.info hostapd: wlan0-1: STA 74:60:fa:a3:ef:1c WPA: pairwise key handshake completed (RSN)
Sat Jan 6 12:38:05 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.12 74:60:fa:a3:ef:1c
Sat Jan 6 12:38:05 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.12 74:60:fa:a3:ef:1c HUAWEI_MediaPad_M5_lite_1
Sat Jan 6 12:39:55 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:41:55 2024 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED b8:27:eb:02:30:51 0 0
Sat Jan 6 12:41:55 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 IEEE 802.11: disassociated due to inactivity
Sat Jan 6 12:41:55 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:41:56 2024 daemon.info hostapd: wlan1: STA b8:27:eb:02:30:51 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sat Jan 6 12:43:55 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:45:55 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:48:01 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:48:10 2024 daemon.info hostapd: wlan1: STA 20:c1:9b:fe:0b:1e IEEE 802.11: authenticated
Sat Jan 6 12:48:10 2024 daemon.info hostapd: wlan1: STA 20:c1:9b:fe:0b:1e IEEE 802.11: associated (aid 3)
Sat Jan 6 12:48:10 2024 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 20:c1:9b:fe:0b:1e 0 0
Sat Jan 6 12:48:10 2024 daemon.info hostapd: wlan1: STA 20:c1:9b:fe:0b:1e RADIUS: starting accounting session 0A52E6CA9EDE9683
Sat Jan 6 12:48:10 2024 daemon.info hostapd: wlan1: STA 20:c1:9b:fe:0b:1e WPA: pairwise key handshake completed (RSN)
Sat Jan 6 12:48:11 2024 daemon.info dnsmasq-dhcp[1350]: DHCPREQUEST(br-lan) 192.168.8.181 20:c1:9b:fe:0b:1e
Sat Jan 6 12:48:11 2024 daemon.info dnsmasq-dhcp[1350]: DHCPACK(br-lan) 192.168.8.181 20:c1:9b:fe:0b:1e linuxpc
Sat Jan 6 12:50:01 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:50:07 2024 daemon.notice netifd: wwan (16284): udhcpc: sending renew to 192.168.1.1
Sat Jan 6 12:50:07 2024 daemon.notice netifd: wwan (16284): udhcpc: lease of 192.168.1.21 obtained, lease time 3600
Sat Jan 6 12:52:01 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:54:01 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:56:01 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sat Jan 6 12:58:02 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
