GL-AXT1800 (Slate AX)
Hello!
I have the GL-AXT1800 (Slate AX). I am wanting to connect to a piece of audio equipment from an iPad.
The GL-AXT1800 (Slate AX) will use an Ethernet cable to connect to the piece of audio equipment.
I need my iPad to connect to the AXT1800 wirelessly. This will not be connected to the internet. It’s just a closed connection.
What is the best way to set up the GL-AXT1800 (Slate AX)?
Thank you
Normal mode, right out of the box, is fine.
Just make sure your iPad will connect to Wi-Fi and disable switching to cellular if your iPad supports it.
Thank you! I appreciate it.
