gl-inet can you upgrade the tailscale client on the GL-ATX1800?
Current is 1.80.
Thanks
Here you go: Script: Update Tailscale on (nearly) all devices
Thanks for the reply with the script. I will have to take a look at it. I would prefer that GL iNet update the package as part of their firmware upgrade process.
They do, but only from time to time.
If you can wait, do so - but the script is highly efficient and helps many people
