GL-AXT1800 Tailscale update
of course - I hope I didn’t suggest the error was caused by your script / I’m sure the error is on my part…
Forgive me, but where can I check to see that my DNS settings are correct?
Within the GL GUI there are several places.
Network > DNS for example. Or within the WAN interface.
I have “manual” selected with the Google dns servers selected…
btw, I’m accessing this router from a distance through Tailscale… would that matter?
In that case, I can’t really help you, since these issues are serious, and I don’t know how you configured your router. By default, DNS is working, so it must be something that you changed.
Maybe, not sure. I don’t use Tailscale at all.
During the update Tailscale will be stopped as well - so it’s advised to use another method of connecting.
ok - Thank You, for your input
sorry - 1 more question: I ssh into the router using Terminal and then perform your script, correct?
Or is it done through Luci?
^+ this one. But ofc it could fail - in that case tailscale might stop.
yes - it’s a new router / i did nothing more than activate Tailscale…
fyi, in case this helps you with some insight:
ajl@Tony ~ % df -h
Filesystem Size Used Avail Capacity iused ifree %iused Mounted on
/dev/disk3s1s1 460Gi 9.4Gi 367Gi 3% 394k 3.8G 0% /
devfs 201Ki 201Ki 0Bi 100% 696 0 100% /dev
/dev/disk3s6 460Gi 20Ki 367Gi 1% 0 3.8G 0% /System/Volumes/VM
/dev/disk3s2 460Gi 5.7Gi 367Gi 2% 1.1k 3.8G 0% /System/Volumes/Preboot
/dev/disk3s4 460Gi 51Mi 367Gi 1% 46 3.8G 0% /System/Volumes/Update
/dev/disk1s2 500Mi 6.0Mi 482Mi 2% 1 4.9M 0% /System/Volumes/xarts
/dev/disk1s1 500Mi 6.1Mi 482Mi 2% 18 4.9M 0% /System/Volumes/iSCPreboot
/dev/disk1s3 500Mi 1.6Mi 482Mi 1% 50 4.9M 0% /System/Volumes/Hardware
/dev/disk3s5 460Gi 77Gi 367Gi 18% 755k 3.8G 0% /System/Volumes/Data
map auto_home 0Bi 0Bi 0Bi 100% 0 0 - /System/Volumes/Data/home
ajl@Tony ~ % uname -m
arm64
Nope, does not help.
Your DNS server is broken, but I don’t know how to troubleshoot this.
Restarting won’t solve the problem, I guess, but it’s worth a try.
Maybe try changing from Google DNS to 9.9.9.9 for testing.
yes, for sure, I have a DNS problem - - from Luci:
ping: bad address ‘google.com’
I’m sorry - i can delete this whole string / I don’t want to hijack this thread with my particular issue… but Thank You, for your help…!!!
Last question on this topic / I have this GL-AXT in “repeater” mode - getting service from a hotel WIFI… could that possibly cause a DNS issue?
Indeed, that causes trouble.
ok - - thank you again - - very useful info
But to be honest, it seems to be some kind of bug. I will try to understand what’s happening and open a bug report here later.
well, I can tell you that I have 2 of the same device / both are connected in Repeater mode… use them to communicate “LAN - to - LAN” … and they work very well using Tailscale… I just wanted to update that software… but could not… :frowning:
thank you for your input, tho
It IS rather odd, tho… of course, I’m connected to the internet through this GL-AXT device - I have great connectivity… It’s a new router / I didn’t make any real changes in configs… happy to let GL-Inet remote into it, if it were to help…
As the same issue/error exists on both routers, I kind of think it may be a bug… can you tell me how I can open up an issue with the Help Desk?
ahhh - - - yes, there may be a bug…
OK - Progress…
I updated to the latest Beta firmware, and that seemed to fix the DNS issue… however your script returns the following error:
root@GL-AXT1800:~# wget -O update-tailscale.sh https://raw.githubusercontent.com/Admonstrator/glinet.forum/main/scripts/update-tailscale/u
pdate-tailscale.sh \
&& sh update-tailscale.sh
–2024-01-26 10:57:27-- https://raw.githubusercontent.com/Admonstrator/glinet.forum/main/scripts/update-tailscale/update-tailscale.sh
Resolving raw.githubusercontent.com… 185.199.110.133, 185.199.109.133, 185.199.111.133, …
Connecting to raw.githubusercontent.com|185.199.110.133|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 3128 (3.1K) [text/plain]
Saving to: ‘update-tailscale.sh’
update-tailscale.sh 100%[==============================================================>] 3.05K --.-KB/s in 0.003s
2024-01-26 10:57:28 (1.08 MB/s) - ‘update-tailscale.sh’ saved [3128/3128]
This script only works on arm64 architecture.
root@GL-AXT1800:~#
HOWEVER:
With the Updated Firmware now uname returns this:
Here’s a screenshot from Luci:
So - Do you, by chance, have a script that will update Tailscale for the ARMv7 Processor rev 4 (v7l) Architecture?
I will look into this.
Thank you very much - - and thank you for helping me identify the problem - - I thought I was going bananas…!
