Hello, I am using a GL-AXT1800 v4.8.2. I am trying to connect to my work’s guest network. The page shows up, I click the required check box and click the button to advance. The next page flashes too briefly to read, then my browser goes to securelogin.hpe.com/cgi-bin/login and the web browser says the page cannot be reached due to DNS address not being found. I tried the first three methods for login portals on the support site and no luck. Any suggestions?
Please check the following:
- Ensure that client devices (e.g., PC or mobile) are using the router’s LAN IP (default: 192.168.8.1) as their DNS server
- Disable encrypted DNS in your browser
- SSH into the router and run the command below:
nslookup securelogin.hpe.com
Additionally, are other devices like your phone connecting properly?
- Done. Was ok
- Done. Turned it off
- Done. Result was: ** server can’t find securelogin.hpe.com: NXDOMAIN
Regarding the last question. My phone can connect correctly by itself to the wifi through the portal, but not when connected through the Slate AX
It's a bit strange.
Please try connecting ATX1800 to a working guest network a few times, then export the logs and send us a private message for analysis.
If you currently have other internet sources (such as mobile phone Tethering, wired, etc.), please connect your AXT1800 to GoodCloud and share it with us remotely according to the tutorial below:
Thank you, I will get this information to you.
Thank you for providing the logs.
We’ve analyzed them, and it appears that the Captive Portal authentication has already been completed:
Sun Apr 12 21:18:13 2026 daemon.info gl-repeater[2686]: (repeater-portal.lua:395) portal detecting...
Sun Apr 12 21:18:15 2026 daemon.info gl-repeater[2686]: (repeater-portal.lua:424) portal detected
Sun Apr 12 21:25:02 2026 daemon.info gl-repeater[2686]: (repeater-portal.lua:364) portal pass
We may need to access your device remotely via GoodCloud to further diagnose the issue.
Could you please follow the previously mentioned steps to grant us remote access?
I tried to connect to GoodCloud. My GL-iNet forum account does not get me in. It says the username and password combination are not valid. Do I need to separately enroll in GoodCloud?
Yes, the forum account is only for the forum.
Goodcloud needs another account registered on https://www.goodcloud.xyz/
Ok, I created an account. I am able to usually successfully authenticate on guest forums. It helps to use my iPhone to get through the captive portal. For some reason my Omarchy laptop was getting tripped up more often.
