I have a GL axt1800 at my office as a vpn server and the speed at office is 1000 MB and I also have a GL axt1800 as a vpn client at home and the speed at home is 100 MB but when I do a speed test at home with the VPN turned on, The speed I received is between 12 MB and 22 MB. Do you have any idea how I can fix it?
My office speed is1000mb down and 550 up, i know the speed not going to be the same because my home speed is 100mb down and 20mb up but i thought will be similar to my home speed.
I am getting better performance using Wireguard on an older GL-iNet AR300M as my VPN server at a family members house, and an AR750S-EXT as my travel router. When the place I’m staying at has fast service, I often have seen up to 40Mbit/sec, which is close to the uplink speed of my family’s internet service.
At your work and at home how are you connecting to the router? At my family’s place I use a short Ethernet cable between my AR300M and their router, and when the place I’m staying at allows me access to the router, I use Ethernet to my AR750S. Sometimes, WIFI is just slow.
