I have a GL-AXT1800, configured: Block Non-VPN Traffic switched on Accessing Following Domain/IP: Not use VPN
192.168.0.2 listed
But I cannot access 192.168.0.2 with this configuration. In my previous Brume, I could use the kill switch and set 192.168.0.2 as an exception no problem.
Thank you - so I’m not going mad. Do you have any advice please, on how I can use the kill switch while also being able to map a drive to a server on the WAN?
First, you do not need to use Killswitch (block non-vpn traffic). If you enable vpn it has killswitch already.
The “block non-vpn traffic” does exactly it shows, you have to use vpn.
Second, to access the WAN, do not need to use vpn policy. Go to Global options and enable “allow access wan”.
If I interrupt the VPN (incorrect password, or switch VPN connectors), traffic goes out directly resulting in leaking. Therefore there is no automatic kill switch?
I have the same issue, I choose the option VPN Policy Base on the Target Domain or IP
and enter some websites not to use the VPN, and this configuration is not working…
Hi - I returned the unit as it was not fit for my purposes. I have an older GL unit which still does the trick. I just hope the firmware doesn’t upgrade and render it useless for me too.
Well, ok, I just followed the community guide that says to use the search area,
I created a thread but at the moment no answers. I am a new user, so I am trying to read everything regards the router, OpenWRT, etc…
Thanks
I can’t get YouTube channel avatars. I tried without adguard. I registered yt3.ggpht.com, ggpht.com in the list of domains. I included redirection of the yt3.ggpht.com domain to yt4.ggpht.com in adguard
