Been trying to get my GL-AXT1800 to work with wireguard client. Ive tried 2 VPN services TorGuard and PrivateInternetAccess. They both connect, but then there is no internet connectivity. I have updated the firmware, restarted the router, and reset it. I am importing the .confg files generated from the VPN sites because im using a dedicated IP. I have tried it without the dedicated IP aswell still wont work.
Anyone have any ideas? Im about to return this thing to amazon
These are the public DNS routers from Google. It is not bad, because it is working. But it is also not in any sense ‘privacy’.
Overall is it a dirty hack or a workaround. In no case I would give it the description ‘fix’.
To understand the basic issue, what was the DNS setup before?
definitely not a fix but sign of another vulnerability in wireguard.
I reported to NordVpn and Keepsolid but they play dumb.
Switched to protonvpn and works
