Hi Dear, Just got the new GL-AXT1800-xxx router and when I try to connect to 193.168.8.1 to land on admin page it’s NOT reaching out to admin page. Getting this error: This site can’t be reached 192.168.8.1 took too long to respond. Tried reseting it but still no LUCK. can anyone suggest what can I do?
Are you using URL http://192.168.8.1 (i.e., http, not https)?
Please try to access it with a browser without plug-ins. Or try turning off the antivirus software on your PC for a short time and try accessing it.
You can also try accessing it with your mobile browser or with App.
Can you reach 192.168.8.1 by pinging it from your PC? Is your PC running a VPN or other proxy?
How are you connecting to the router, wired or wireless. If wired, is your device set to a 192.168.8.0/24 IP.
