HI All,
as they is any command or code changes to make B-1300 or S-1300 disable POE feature and when i connect to POE wan device getting slow so i want to make sure POE feature is disabled.
please help
HI All,
please help
B1300 has PoE while S1300 does not.
It is a hardware feature and cannot be disabled from software. The only way to disable PoE on B1300 is to open the case and remove the PoE module directly.
as per mention here b1300 support POE mine b1300 is working on POE power but facing too much packet loss if using POE in case of networking stuff
