GL-B1300 (3.211) no-ip.com?
Hello! I am trying the ddns configuration, but I saw that no-ip.com does not exist … Why?
There is no-ip.pl, but it is not the same thing
Can’t use no-ip.com ??
Thank you
Make sure that the ddns-scripts_no-ip_com, ddns-scripts and luci-app-ddns packages are installed (if not already installed), then no-ip.com will be available in LuCi via LuCI → Services → Dynamic DNS.
Thanks a lot for your help
yikes - configuring NOIP is a total hassle… not very user friendly - I’ve also read that it was originally removed due to a privacy issue… so question:
Is there any reliable, safe, way to update DUC from Luci ?
Hello, how does one install ddns-scripts_no-ip_com, ddns-scripts and luci-app-ddns packages? thanks in advance for any help you can provide.
