I have 2 VLANs correctly setup on my b1300. The devices from both of them can reach internet, but I cannot connect to a device on a different VLAN: e.g. if I try to connect from my laptop (on LAN vlan) to my Home Assistant (on my IoT vlan).
I can correctly ping/traceroute the opposite VLAN’s devices, but I have the impression some firewall rule is still blocking the responses.
Can you help me to spot the blocking part?
From LAN vlan (192.168.8.0):
$ traceroute 192.168.10.5
traceroute to 192.168.10.5 (192.168.10.5), 64 hops max, 52 byte packets
1 gl-b1300 (192.168.8.1) 22.718 ms 2.851 ms 3.140 ms
2 home-assistant (192.168.10.5) 4.245 ms 4.979 ms 4.098 ms
$ curl http://192.168.10.5 -p 8123
curl: (7) Failed to connect to 192.168.10.5 port 80 after 14 ms: Connection refused
curl: (7) Couldn't connect to server
From IoT vlan (192.168.10.0):
$ traceroute -p 8123 192.168.8.25
traceroute to 192.168.8.25 (192.168.8.25), 64 hops max, 52 byte packets
1 gl-b1300 (192.168.10.1) 21.246 ms 1.524 ms 2.135 ms
2 raspberry1 (192.168.8.25) 3.396 ms 5.081 ms 3.223 ms
/etc/config/firewall
cat /etc/config/firewall
config rule
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fe80::/10'
option src_port '547'
option dest_ip 'fe80::/10'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'bad-header'
option limit '1000/sec'
config rule
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule 'guestzone_dhcp'
option name 'guestzone_DHCP'
option src 'guestzone'
option proto 'udp'
option dest_port '67-68'
config rule 'guestzone_dns'
option name 'guestzone_DNS'
option proto 'tcp udp'
option dest_port '53'
config rule 'sambasharewan'
option src 'wan'
option dest_port '137 138 139 445'
option dest_proto 'tcpudp'
option target 'DROP'
config rule 'sambasharelan'
option src 'lan'
config rule
option name 'IoTzone_DHCP'
option proto 'udp'
option src 'IoTzone'
option dest_port '67 68'
option enabled '0'
config rule
option name 'IoTzone_DNS'
option enabled '0'
config rule
option proto 'udp'
option dest_port '5353'
option name 'allow mDNS'
option src_port '5353'
option dest_ip '224.0.0.251'
option src '*'
config rule
option proto 'tcp'
option dest_port '8008-8009'
option name 'Chromecast 8008-8009'
option dest 'IoTzone'
option dest_ip '192.168.10.10'
option src 'lan'
config rule
option proto 'udp'
option dest_port '32768-61000'
option name 'Chromecast 32768-61000'
option src 'lan'
config rule
option proto 'tcp'
option dest_port '8443'
option name 'Chromecast 8443'
option src 'lan'
config defaults
option input 'ACCEPT'
option output 'ACCEPT'
option disabled '0'
option drop_invalid '1'
option forward 'REJECT'
option syn_flood '1'
config zone
option name 'lan'
option forward 'ACCEPT'
option network 'lan'
config zone
option name 'wan'
option masq '1'
option mtu_fix '1'
option network 'wan wan6'
option input 'DROP'
config include
option reload '1'
config include 'glfw'
option type 'script'
option path '/usr/bin/glfw.sh'
option reload '1'
config include 'mwan3'
option path '/var/etc/mwan3.include'
option reload '1'
config zone 'guestzone'
option name 'guestzone'
option network 'guest'
option input 'REJECT'
config forwarding 'guestzone_fwd'
option dest 'wan'
config zone
option name 'IoTzone'
option network 'IoT'
config forwarding
option dest 'wan'
option src 'lan'
config forwarding
option dest 'lan'
config forwarding
option dest 'wan'
config forwarding
option src 'lan'
config include 'qcanssecm'
option path '/etc/firewall.d/qca-nss-ecm'
option family 'any'
option reload '0'
config include 'gls2s'
option path '/var/etc/gls2s.include'
option reload '1'
config include 'glqos'
option path '/usr/sbin/glqos.sh'
option reload '1'
