I want guests to access an Airplay screen / speaker, can someone confirm that the guest network doesn’t isolate clients?
thanks
It isolates clients by default.
You can modify it in LuCI.
Network → Wireless → Edit the Guest SSID → Advanced Settings
Thank you, can you confirm that the IP range of the main network is isolated from the guest network.
By default your Private Network clients will be assigned a IP on the 192.168.8.0/24
subnet while the Guest Network client devices will show a 192.168.9.0/24
subnet IP.
GL GUI → Network → LAN
By default, the client device in the guest cannot access the main network.
